1972 LT2 shifter oil seal
Replied by MarkT on topic 1972 LT2 shifter oil seal
Thanks for the updates...  and after one more post from you, the post after that should allow you to post your own links.
1drv.ms/f/c/19efa8465f6112d0/EkFAKSETaUZ...msGPWvjZUXw?e=srdK56
20 Aug 2025 13:51 #21
P.S. That last link is asking me to sign in so there might be an issue with the pics being flagged for sharing or something?  The earlier link you posted just let me view the pics.
20 Aug 2025 13:54 #22
Replied by RT325 on topic 1972 LT2 shifter oil seal
Can see those pics through Marks live link by hitting them in the link. Blind plug you mentioned I think would refer to the little black plug just behind the broken cover. You don't know how lucky you are with that plastic cover as it's all intact & in the worst case can break the entire end off the selector drum. Without seeing the clutch basket I'd just leave it, not replace. I'd guess that's the least of your worries & I've had bad cases still operating normally. Just note it for later. Check sprocket nut is tight & check the seal behind for a reasonable fit to the sleeve/spacer.
Last edit: 20 Aug 2025 14:50 by RT325.
20 Aug 2025 14:48 #23
Replied by Schu on topic 1972 LT2 shifter oil seal
I typically file the clutch baskets until the grooves are gone or greatly reduced. You might want to check the clutch push rod to see if its bent. Mine was obviously bent from a past chain derailment which broke the plastic cap just like yours.
21 Aug 2025 05:17 #24
Replied by Lizeec on topic 1972 LT2 shifter oil seal
Another item to note, looking at your countershaft sprocket you are in need of new sprockets and a chain or you might not get so lucky with damage only to the little plastic cover, many times when a drive chain gets thrown it will damage that plastic cover and the selector drum and if you are really unlucky it will damage the engine cases.
21 Aug 2025 11:37 #25
  • n811
  • n811's Avatar Topic Author
Replied by n811 on topic 1972 LT2 shifter oil seal
Absolutely, LIZEEC! New sprocket and chain are added to the parts list, as well as rear sprocket while I'm at it. I seem to love spending money on this bike XD
21 Aug 2025 13:29 #26
