Clutch pushrod
  • kitkatman
  • kitkatman's Avatar Topic Author
Clutch pushrod was created by kitkatman
Hi Everyone,
 Could someone tell me the correct length of the clutch pushrod for the RT2. Also is the same pushrod used for the RT1.
    Thanks. Alan.
26 Jul 2025 13:34 #1
Replied by Swoop56 on topic Clutch pushrod
I can't give you a length , but the RT1 and RT2 use different pushrods .
26 Jul 2025 14:39 #2
  • RT325
  • RT325's Avatar
  • Platinum Member
  • Platinum Member
Replied by RT325 on topic Clutch pushrod
The good thing I guess is if you make it too long at least you can pull it out the left side & shorten it a bit. Exact length may vary depending on if aftermarket fibers fitted etc.
26 Jul 2025 14:48 #3
Replied by MarkT on topic Clutch pushrod
There are two pushrods, long rod and then the short "nail head" one...  according to parts lists they appear to be the same part number for the 250/360 from 68 to 73?
Most common "length" issue is the 5/16" ball is missing between the two pushrods.
The following user(s) Liked this Post: 1971DT250, Papawhellie, Snglsmkr, Ht1kid
26 Jul 2025 15:54 #4
Replied by 1971DT250 on topic Clutch pushrod
Length is 7.20". With the clutch properly assembled and installed the rod sticks out 1.25".
I have a NOS rod part # 183-16357-00 still in the package. I have several original printed parts manuals for the '68-'73 250 and 360 Enduros. Some have # 214-16357-00 and some have # 183-16357-00. One of my '71 DT1E manuals looks like it was in a dealer back in the day. The part # prefix 214 was crossed out and 183 handwritten. I've had dozens of motors apart and I haven't seen any difference in the push rods.
The following user(s) Liked this Post: MarkT, Swoop56, SKYDANCER46, Ht1kid, Sneezles61
26 Jul 2025 17:45 #5
  • kitkatman
Replied by kitkatman on topic Clutch pushrod
Clutch adjusting screw is going in to far, not much thread left for locknut. So will get a piece of silver steel Rod and make a new one a few mill longer.  Once again thanks for all reply’s. Alan.
27 Jul 2025 08:02 #6
Replied by Gr8uncleal on topic Clutch pushrod
If there should be a ball bearing fitted, is it there (see Mark's earlier reply)?
Last edit: 27 Jul 2025 11:14 by Gr8uncleal.
27 Jul 2025 11:14 #7
Another pitfall is the worm gear has split and slipped?
Or something wrong with the clutch pack assembly?  (As simple as a loose inner hub nut.)
Making a new longer than original pushrod seems like, at best, a patch to mask the real issue.
27 Jul 2025 11:30 #8
  • RT325
  • RT325's Avatar
  • Platinum Member
  • Platinum Member
I think Mark mentioned the 5/16 big ball between the mushroom & rod which won't fall out unless you had the clutch off & leant it to the right a bit, if you had the mushroom out at all. But there's a 1/4 ball set into the actuator which shouldn't fall out as lightly crimped in but have a look just incase, as that's about the difference you're looking for by the sound of it.
27 Jul 2025 14:17 #9
