Battery Ground Wire
- quidger
Battery Ground Wire was created by quidger
1972 RT2 360
Whrre does the battery ground connect?
I only have one black female plug that is open and it’s about half wsy up the main harness by itself. I have a black plug on the flasher under the battery box that is already occupied.
I appreciate any suggestions.
15 Jul 2025 08:09
Replied by Gr8uncleal on topic Battery Ground Wire
It doesn't - from battery straight to the frame. I'll post a photo after tea.
Don't connect anything to the sole black female coming from the mag, at about carb height - your bike won't run if you do!
Edit - photo now attached. Battery screwed/bolted to frame using a ring connector.
The following user(s) Liked this Post: MarkT, DVM, Snglsmkr, Ht1kid
- quidger
Replied by quidger on topic Battery Ground Wire
Thanks Gr8uncleal,
My bike didn’t have a battery.. The recommended battery I bought has a male connector for the ground. I assumed there would be a female connector. Easy to add the ring connector.
what is the lone black female connector in the middle of the harness used for?
16 Jul 2025 06:09
"what is the lone black female connector in the middle of the harness used for?"
Some sort of service wire for checking the ignition, but more than that I don't know.
16 Jul 2025 06:27
Replied by RT325 on topic Battery Ground Wire
The spare short female black on the mag loom is tied into ignition so don't go there. Any other black in the main loom should find its way to earth. Easy to check. Ignition earth to stop the motor should be black white so don't go there. Still best to earth battery to the frame I think. If you have a battery male earth just take a short piece & fit a ring one end & female the other. Should be good. Just my opinion & others may disagree.
The following user(s) Liked this Post: DVM
16 Jul 2025 14:53
