Leaking oil pump
  • Barrya
  • Barrya's Avatar Topic Author
Leaking oil pump was created by Barrya
My 2 stroke oil pump on my ct3 is leaking from the white plastic bleeder wheel...i know there is an oil seal behind this...my question is can this seal be fitted externally or does the whole pump need to be stripped and the seal fitted internally...thanks
21 Mar 2025 02:03 #1
Replied by MudRock on topic Leaking oil pump
My oil pump also leaked and left a puddle of oil on the floor. I can't tell where it leaked from. Does anyone know if this would require a rebuild or just a seal replacement somewhere?
25 May 2025 18:36 #2
  • Barrya
Replied by Barrya on topic Leaking oil pump
Mine did this....theres a seal behind the white pully which caused mine...remove white wheel and replace....you can use chaulk powder etc to identify leak area
26 May 2025 07:12 #3
Thank you! I'll give the a try.
26 May 2025 10:32 #4
Replied by Tom P on topic Leaking oil pump
I replaced the seal behind the white wheel, but it still leaks a bit. Also replaced the fiber washers on the upper fitting with copper washers, but now I've resigned myself to just removing the cover on occasion and soaking up whatever leaked. Usually half a teaspoon or less after 30 miles or so. Thinking of leaving a tampon in there :o)
The following user(s) Liked this Post: RT325, Schu, Ht1kid
Last edit: 29 May 2025 09:37 by Tom P.
29 May 2025 09:36 #5
Replied by Ht1kid on topic Leaking oil pump
Great Idea.
29 May 2025 11:27 #6
Replied by Schu on topic Leaking oil pump
So Tom’s CT is the one with the little string dangling from the right side cover..
The following user(s) Liked this Post: Swoop56, Ht1kid, Tom P
29 May 2025 12:21 #7
No tampons in the house, so I stuffed a couple big cotton balls under it. More manly...
29 May 2025 12:36 #8
Replied by Sneezles61 on topic Leaking oil pump
I’m happy I’ve got green oil.
Sneezles
29 May 2025 15:22 #9
  • RT325
  • RT325's Avatar
  • Platinum Member
  • Platinum Member
Replied by RT325 on topic Leaking oil pump
Strung a disposable nappy under my "67 Holden when the rear crank seal started dripping.
Did the job ok haha--wait a minute dear i've gotta change my nappy before we drive to town.
Actually that's not funny any more aproaching age 79 haha.
That brings back vivid memories of a competitor in our castrol 6 hour roadrace in nz in the "70's & his Guzzi was leaking around the head gasket. So went down to the local chemist & probably cleaned them out of tampons then forced them in between head & cylinder.
Can't remember how well or how long it worked for--or if they all spat out on the circuit.
Maybe he won his class when the others slid off behind him!!.
Last edit: 29 May 2025 18:28 by RT325.
29 May 2025 18:18 #10
