RT2 360 Engine Re-assembly
- quidger
Replied by quidger on topic RT2 360 Engine Re-assembly
Got it! Will get it on YouTube.
26 Oct 2023 15:07
#11
- quidger
26 Oct 2023 16:46
#12
Replied by MarkT on topic RT2 360 Engine Re-assembly
Might be normal. Try spinning the clutch input shaft as you try shifting up and down. They don't like to shift unless spinning.
The following user(s) Liked this Post: Ht1kid, msavitt
26 Oct 2023 16:59
#13
Replied by RT325 on topic RT2 360 Engine Re-assembly
I'm guessing you're in neutral so you'll have a long movement up & down like you show because when it bumps into the pin at the end of the long movement it only needs to move the drum a little bit to fall into first or second depending which way ya going.
Plus what Mark said, turn one shaft. Only need a little to line up the dogs, but a spin will work for sure.
- quidger
Thanks, guys.
I’ll give it a spin.
27 Oct 2023 05:28
#15
