1972 RT1 360 - No Spark
Replied by RT325 on topic 1972 RT1 360 - No Spark
Yay, great news. Next the startup. Good luck with that.
14 Jul 2023 16:53 #21
Replied by Ht1kid on topic 1972 RT1 360 - No Spark
If you haven’t cleaned the inside I would use evaporust does a super job any pictures of the inside of the tank you got SPARK.
14 Jul 2023 16:58 #22
Replied by shyted on topic 1972 RT1 360 - No Spark
Start with Evaporust Mike or electrolosys. Both are quite passive when compared with other stuff.
You can make up electrolosys easy . An insulator to go over the fuel tank filler (wood or plastic) some baking soda and mix it at a dessert spoon full to a litre of distilled water. You then want a 12V battery charger( You can run it through a battery if you like) fill the tank ,suspend a mild steel coat hanger bent to shape so as not to go to earth in the tank,make a hole to pass it through on your insulator,earth on the tank,live on the coat hanger wire, switch on and leave it for 24 hrs. Job done. You can repeat. Then you can use your liner kit to finish off the job much easier.
14 Jul 2023 17:00 #23
Wow SHYTED that sounds like a cool idea i think i'd be dangerous at doing lol--but cool idea for sure.
Be good to see a video if any out there. I guess google is my friend.
15 Jul 2023 02:50 #24
