AT3 Sans Electric Foot.
Replied by MarkT on topic AT3 Sans Electric Foot.
2strokenewb... USA did not officially get a Yamaha 125 Enduro without electric start until the new monoshock model in 1978.
Kick only models in the US could be the "MX"... someone "might" have converted a 12v generator/starter model to a 6v magneto (quite a bit of work, wiring harness and a lot of parts need to be changed)... someone might have installed a Powerdynamo 12v magneto (or equivalent aftermarket magneto to replace the starter/generator)... someone could have served in the military and brought a non-US model home with them... just to name a few.
It also would not be unheard of to find a starter button missing (or removed by a seller because e-start doesn't work)... of course that makes it "kick start only" but it's still a 12v starter/generator model.
- 2strokenewb
Replied by 2strokenewb on topic AT3 Sans Electric Foot.
This page says mine is a USA model by VIN, and it does not look like it's been converted. I will have to do some more investigation. www.legends-yamaha-enduros.com/vin-numbe...jLdSHAtlQ7u-HQd419XR
23 Nov 2024 19:14
#12
- 2strokenewb
Well, I figured it out. It just does have electric start. only clicks the solenoid and just barely turns the engine
24 Nov 2024 17:18
#13
Replied by RT325 on topic AT3 Sans Electric Foot.
Ok that's good, now were on the right track.
If it runs & the battery has water [if that type] then you'll see it charging by shining the headlight on the wall in the dark & with it at a slow idle it'll dull a bit then come up at just above idle & hold as revs increase.
If nothing changes then i'd look at brushes although if starter is trying to turn then maybe not brushes & might be just an old battery past its "useby".
If you have a DC volt meter across the battery then should see the voltage rise above idle but headlight idea is easy to do--can hear it charge 'if it is' as it struggles a little as it cuts in--electric brake.
