Re:Building the AT2 sleeper hot rod
- dose
Replied by dose on topic Re:Building the AT2 sleeper hot rod
Very clean job. I can't tell where he did it.
I did mine before the shock pivot to lean them back more.
On my other arm I want to extend after the shock to see which way I like better
Scootern29 set up my shocks for the latter
I sleeved and rosetted in chromoly tubing
Sent from my iPhone using Tapatalk
72 AT-2 with some mods
11 Nov 2015 22:13
#51
- Scootern29
Replied by Scootern29 on topic Building the AT2 sleeper hot rod
Lookin good dose. One thing to be aware of and you may already know this, moving the shock mount back is going to change the collapsed length of the shock mounts. The Curnutt collapsed length is right around 9 1/8 inches. Make sure you have that or more between the shock mounts with the tire hitting the fender.
12 Nov 2015 09:10
#52
- dose
Replied by dose on topic Building the AT2 sleeper hot rod
If my measurements are correct I should have 3/4"-1" of clearace at full stroke.
that may change when I put on a knobby tire and I will re-measure
12 Nov 2015 19:18
#53
- Scootern29
Cool.
12 Nov 2015 19:28
#54
- dose
Still waiting on a tube so I can put on my aluminum wheels
12 Nov 2015 19:40
#55
- DEET
- Moderator
Replied by DEET on topic Re:Building the AT2 sleeper hot rod
Not that it matters, but if you extended the swing arm behind the brace, you should be able fit a bigger tire in there (if you ever wanted to).
But it would have been harder to keep the alignment and the final width by doing the cutting and welding behind the brace.
I was just thinking how it would look with a 140-18 on the rear....
12 Nov 2015 20:24
#56
- dose
I forgot to put the brake on when I weighed the aluminum wheel but it's about 2 pounds less unsprung weight
09 Dec 2015 23:37
#57
- dose
Got my mx250 fork mocked up and the front 21" wheel laced and trued using the scootern21 method
Thanks for the idea Scott
The following user(s) Liked this Post: Scootern29
09 Dec 2015 23:40
#58
- dose
Tapered bearings are a nice upgrade if you have your clamps off
My mx fork next to the at2 fork
And a smaller tailight. Keeping it barely legal
The following user(s) Liked this Post: bluntz465
10 Dec 2015 21:46
#59
- dose
The bike is a whole new animal now. After this pic was taken I added 3" to the kickstand! Haven't ridden it yet because it's been dumping snow here the last couple of weeks
27 Dec 2015 10:10
#60
