RT2 jumping (?) out of 3rd gear
Replied by RT325 on topic RT2 jumping (?) out of 3rd gear
www.partzilla.com/catalog/yamaha/motorcy...968/dt1/transmission
Gears 5 & 7--then 22 & 21 same gears. Just a bit of useless info haha.
29 Oct 2022 15:05
#31
- Ren124
Replied by Ren124 on topic RT2 jumping (?) out of 3rd gear
Hi again, I thought it would be useful (at least for me) to summarise where we are - and hopefully move on to getting in the parts and rebuilding.
1) I have a DT1 shifter system, cam and forks
2) I have a 15t main (clutch) shaft (poss RT2)
3) I have a DT1/RT1 drive shaft (without the step)
4) I have a mix of gear ratios (1-5) 38/15 33/20 23/19 24/21 19/23 (mostly DT1 with RT2 first dunno what 2nd
Where I go from here I think will be determined by which drive shaft I can source to replace the busted one.
But I have a couple of questions.
You've mentioned large/small teeth gears - is the difference in height or width etc? I'd likt to be able to identify to make sure I'm matching right
Would the DT1 shift forks etc be 100% reliable on later gears, shafts etc
Many thanks
D
Many thanks
D
01 Nov 2022 10:44
#32
Blimey, i'd say your going to be teaching us. Coarse tooth gears of early type are obvious if you had the two sets to compare. Coarse style is just less teeth per circle. I'm wondering if it might be better to look on ebay for a complete RT2-3 trans with drum & selectors & all. That's if your cases have the hole for the extra selector shaft which i guess it must have. Good thing about yamaha is that so much is interchangeable through the model "70--"73.
01 Nov 2022 14:17
#33
Replied by MarkT on topic RT2 jumping (?) out of 3rd gear
Yamaha has service bulletins on the gears and what goes with what. I think there might be some in back of 1971 DT1E service manual in tech library.
The following user(s) Liked this Post: Ren124
01 Nov 2022 20:31
#34
