CT3 Speedo Drive Gear rusted to hub..........(Need advice on how to remove)
  • Quartermaster35
  • Quartermaster35's Avatar Topic Author
This drive gear seems to be rusted to the hub......... any advice on how to remove?
1973 Yamaha CT3 175
Prior Bikes:
1973 Suzuki TS90
1977 Yamaha IT175
1978 Suzuki 390SP
1980 Yamaha 175 Tri-Moto
1969 Yamaha DT1 250
1981 Yamaha XS650 Special
1982 Suzuki GS550ES
1982 Honda 250R
1984 Honda Nighthawk "S"
2005 Kawasaki KLR650
16 Oct 2021 14:32 #1
Probably equal measures of good penetrating oil and patience .
16 Oct 2021 14:37 #2
  • RT325
  • RT325's Avatar
  • Platinum Member
  • Platinum Member
I've got mine off in the end by using long nose pliers & forcing on the teeth but wonder if you fitted a tube over it to protect the seal then apply heat down through the tube. Seal comes out easy enough & can re-use it if ya careful.
16 Oct 2021 15:25 #3
  • Quartermaster35
I have been heating it on and off today but hasn't moved much yet........ Will be soaking overnight.
(Hoping hoping)
1973 Yamaha CT3 175
Prior Bikes:
1973 Suzuki TS90
1977 Yamaha IT175
1978 Suzuki 390SP
1969 Yamaha DT1 250
1982 Suzuki GS550ES
1982 Honda 250R
16 Oct 2021 17:32 #4
I've had some luck trying to rotate gear CCW by the flats so it climbs the little gear... works really good if little gear is stuck
16 Oct 2021 18:07 #5
  • RT325
  • RT325's Avatar
  • Platinum Member
  • Platinum Member
If all else fails is there room to drill a couple of opposing holes from the outside in to tap the back of the gear with a punch or nail. Best pull the little gear out if you have an un-do thingy & just get it out of the way. With that gear removed & if any slight movement you can work at it with more room just nosey pliers on the gear teeth--won't hurt it if you don't slip.
16 Oct 2021 20:21 #6
  • Quartermaster35
I gave up on removing this and ordered a different hub off of Ebay for $30...... Problem solved!
1973 Yamaha CT3 175
Prior Bikes:
1973 Suzuki TS90
1977 Yamaha IT175
1978 Suzuki 390SP
1969 Yamaha DT1 250
1982 Suzuki GS550ES
1982 Honda 250R
The following user(s) Liked this Post: LETSJET
25 Oct 2021 09:59 #7
