CT3 - TRANSMISSION PROBLEM
- Gallotti
CT3 - TRANSMISSION PROBLEM was created by Gallotti
Hey guys,
can anyone tell me how to avoid this problem? I had already shut the engine down convinced it was working and then realized something was wrong with the gear shift engagement.
I apologize for my English.
Thanks a lot for the help.
16 Oct 2021 03:02
Replied by MarkT on topic CT3 - TRANSMISSION PROBLEM
You are missing the washer and clip on the other side of the shift shaft. Clip fits in groove in shift shaft next to seal.
The following user(s) Liked this Post: Gr8uncleal, HouseofEnduro
16 Oct 2021 04:05
- Gallotti
Replied by Gallotti on topic CT3 - TRANSMISSION PROBLEM
I'm ashamed....I'm a complete idiot
16 Oct 2021 05:09
You're fine. If you knew half the mistakes I've made you'd feel like a genius!
Also note that the transmission usually won't shift through all the gears unless you are spinning the shafts.
16 Oct 2021 05:51
