AT2
  • RobertE
  • RobertE's Avatar Topic Author
AT2 was created by RobertE
Does anyone know what the piston to cylinder clearance should be on a fresh bore for a 72 AT2??   The AT1 shows .0016-.0018, but the AT2 has a reed s;ystem and the piston is different. Would the specs be the same?
13 Oct 2021 16:58 #1
  • RobertE
Replied by RobertE on topic AT2
Whoops, finally found the tech manual for the 72. .0016-.0018 is correct for the AT2.
13 Oct 2021 17:19 #2
  • RT325
  • RT325's Avatar
  • Platinum Member
  • Platinum Member
Replied by RT325 on topic AT2
My book says "in mm" .040--.045mm which is the same as what you have in inches. My book says same for AT2 & AT3 etc. Think you measure it just above the windows as starts to taper if you go higher up, but measurement at the skirt base & 'there' should be the same. 18mm up comes to mind but that might've been YZ's with the cutaway skirt.
13 Oct 2021 17:28 #3
