Head gasket on RT2
- MK19
Head gasket on RT2 was created by MK19
Does the RT2 have a head gasket? I just took the cylinder head off mine and found no gasket. There is a copper ring just around the top to the piston but no gasket between the main body of the cylinder and the head. Is that right or do I want to be putting a gasket in there along with the copper ring when I put it back together?
28 Sep 2021 02:33
Replied by Gr8uncleal on topic Head gasket on RT2
The copper ring is the gasket.
The following user(s) Liked this Post: MK19
28 Sep 2021 02:52
Replied by RT325 on topic Head gasket on RT2
Yep copper ring does the trick. Could anneal it if ya wanted to help seal better but must admit i've not done that to mine & seals good. Effectively held down in 8 places--i never thought of it like that, till now.
28 Sep 2021 04:37
- MK19
Replied by MK19 on topic Head gasket on RT2
Thank you. So I can use the same gasket multiple times? When might I know that it needs replacing?
29 Sep 2021 01:31
Pretty much never. I've just kept using them without issue. Good system. Annealing--softening by heating until 'just' red then quenching in cold water softens it to theoretically help it seal better & allow it to follow any slight imperfections while tightening the head i guess. But i don't recall ever doing mine or needing to. If you overheated the annealing process then it might blister so that'd ruin it.
29 Sep 2021 03:17
- Sneezles61
Replied by Sneezles61 on topic Head gasket on RT2
Good stuff to know... My tank is getting close to MT and I'd like to check my timing... That stubborn ol Mule.. I know... its the nature of the beast!...
Sneezles61
Sneezles61
29 Sep 2021 06:41
- Rick C.
Replied by Rick C. on topic Head gasket on RT2
Just cause I like pictures...
The RT2
The RT2
29 Sep 2021 11:12
I've seen that pick on partzilla & don't know why they show a 250 with 360 inset pic. Just to confuse us i guess.
29 Sep 2021 14:48
