CT3 clutch
  • ksours
  • ksours's Avatar Topic Author
CT3 clutch was created by ksours
Experience knows best. Getting close to replacing a clutch ( bike sat for years so it's on my list ) .
1- What clutch components are recommended for a CT3. Brand, etc.
2- Do I need the rubber rings
3- Can I clean the metal rings and reuse
4- Is it wise to replace the springs even if they look fine
10 Sep 2021 05:36 #1
Replied by Pete-RT1 on topic CT3 clutch
Can't advise on brand as the ones I've used in all my CTs were from Yambits in the UK.
You can discard the rubber rings.
Yes, you can re-use the metal rings so long as they are flat.
You can re-use the springs as long as the length is in spec (free length 31.5mm -1mm tolerance).
Yamaha CT3 (in bits)
The following user(s) Liked this Post: MarkT, ksours
10 Sep 2021 07:48 #2
  • ksours
Replied by ksours on topic CT3 clutch
ty
10 Sep 2021 08:04 #3
Replied by Swoop56 on topic CT3 clutch
I usually find the clutch springs have sagged a bit on inspection .
As they are relatively cheap , I just replace them as a matter of course .
I'd rather spend a little more money up front , than have to go back and do the job again .
10 Sep 2021 14:41 #4
