High beam indicator
  • gassytroll
  • gassytroll's Avatar Topic Author
High beam indicator was created by gassytroll
I'm having trouble removing the burnt out indicator bulb. What is the proper technique?
01 Aug 2021 18:37 #1
Replied by DEET on topic High beam indicator
Use a tight straw over the end...push down and twist.
The following user(s) Liked this Post: JayB, Schu, Jack, gassytroll
01 Aug 2021 18:47 #2
  • Gr8uncleal
  • Gr8uncleal's Avatar
Replied by Gr8uncleal on topic High beam indicator
For jiggered bulbs, which might also be rusted in, I have carefully broken the bulb glass and used some narrow ended pliers to grab the metal part of the bulb and push down and twist this to remove. I've found that the bulbs can be awkward buggers to remove at the best of times.
Last edit: 01 Aug 2021 23:57 by Gr8uncleal.
01 Aug 2021 23:57 #3
  • gassytroll
Replied by gassytroll on topic High beam indicator
Thanks for the input
02 Aug 2021 22:37 #4
Replied by RT325 on topic High beam indicator
Just be careful & wear a leather glove. Or piece of fuel hose over the glass to push down & turn.
The following user(s) Liked this Post: Rick C., MarkT, Jack
03 Aug 2021 04:33 #5
  • gassytroll
The fuel line worked. Thanks
03 Aug 2021 20:02 #6
