AT3 removing the rotor - changing the brishes
- Chajoma
Replied by Chajoma on topic AT3 removing the rotor - changing the brishes
Shyted, you are smart. I have the workshop manual but haven't looked so I am dumb.
- Chajoma
SWOOP56, I suspected as much. Any idea where I can get the tapered bolt tool from? I'll have a search myself...
Replied by RT325 on topic AT3 removing the rotor - changing the brishes
It's not tapered, just parallel. One in my pic is genuine from when i worked at the Yam dealer. Fits any of the armature models twins & singles by memory--only one i've ever used anyway.
09 Jul 2021 04:39
#13
Rendering Error in layout Message/Item: fopen(http://open.api.ebay.com/shopping?callname=GetSingleItem&appid=makotosu-08bc-47da-8e7d-68e3ee6e51ca&siteid=0&responseencoding=JSON&ItemID=381789688313&version=889&trackingid=&trackingpartnercode=9): failed to open stream: php_network_getaddresses: getaddrinfo failed: Name or service not known. Please enable debug mode for more information.
- Chajoma
UPDATE: I managed to get the correct puller from my local Yamaha dealer. It all came apart OK and the new seal is fitted.
And it has cured my tick-over problem - woohoo!
Unfortunately I haven't managed to fix my charging problem at the same time. I've started a new topic on that one...
06 Aug 2021 08:50
#15
