Sad DT3
- apex
- Content Contributor
Replied by apex on topic Sad DT3
...to what my DT3 carb "should" be. No carb came with this Sad DT3. The purpose of this exercise is, will it run? There's no chain on it, and I don't plan to ride it at this point. Just want to hear it run, since all my garage Enduro dollars are wrapped up in this house we just moved into (for the time being).
Allrighty Then
19 Apr 2021 14:57
#11
Replied by RT325 on topic Sad DT3
Hey i'm with you. Just wanna hear it run. Lot of my bikes started off like that--umm, & still are!!.
19 Apr 2021 16:47
#12
- loner
Replied by loner on topic Sad DT3
Kudo's to you Apex! I feel than anyone who does their best to restore any vintage bikes to their previous glory deserves a sainthood.
19 Apr 2021 17:33
#13
- apex
The following user(s) Liked this Post: t-bone, RT325, Swoop56, Pete-RT1
Replied by MarkT on topic Sad DT3
Congratulations!
First starts are always a great moment!
The following user(s) Liked this Post: apex
20 Apr 2021 09:28
#15
- asco
Replied by asco on topic Sad DT3
Alrighty Then..
saved another 250..
a
saved another 250..
a
YAMA-LAND RESTORATION,
( 818 ) 521-2109
1971 CT1-C (BRANDY)
1970 DT1-C (MONICA)
1972 AT2M (ZIFFLE)
1970 CT1-B (HULK)
1971 DT1E (GINA)
1970 CT1-B (CLIDE)
( 818 ) 521-2109
1971 CT1-C (BRANDY)
1970 DT1-C (MONICA)
1972 AT2M (ZIFFLE)
1970 CT1-B (HULK)
1971 DT1E (GINA)
1970 CT1-B (CLIDE)
20 Apr 2021 13:22
#16
- shyted
Replied by shyted on topic Sad DT3
Well Apex you'll have to change the title of the thread now to" Not sad anymore DT3.
Great stuff that you got it to run.
I would just like to give some info here on cleaning coils up.
You can buy electrical insulating varnish from suppliers or ebay relatively cheap. It lasts for an age .
I have reproofed several coils after cleaning them up and then you have no problem. You can also but the white fabric insulation that shrouds the copper wire cheaply. The fibre tape however , is expensive but you can make your own with the varnish and plaster board jointing mesh.
Regards Dave
Regards Dave
21 Apr 2021 02:50
#17
- apex
Thanks all. Yes it's Not Too Sad anymore. But, what next? Just poked around eBay a little bit, and some of the key items missing, like the tank, carb., those are hard to come by as cheaply as they used to be! WOW! And scarce, eBay used to be loaded with these parts, guess guys are holding on to their parts? Carb for $160, RT3 tank $161.
Allrighty Then
21 Apr 2021 11:05
#18
- apex
Why do we always mention to check your brakes? This is the not as Sad DT3 rear brakes when I pulled the brake plate off.
Allrighty Then
The following user(s) Liked this Post: Rick C., Largey
- Mothersbaugh
Replied by Mothersbaugh on topic Sad DT3
Always good to mention this again..........and again and again!
The following user(s) Liked this Post: Rick C., Sneezles61
11 Jun 2021 10:53
#20
