Float bowl gasket.
- Yamrt3
Float bowl gasket. was created by Yamrt3
Do I put the float bowl gasket on dry or with any type of sealer as well?
Asking because this is my first carb rebuild and I don't need any mistakes. Thanks.
12 Apr 2021 13:28
Replied by Gr8uncleal on topic Float bowl gasket.
MarkT recommended soaking in petrol for a while, otherwise it might leak for a day or so.
12 Apr 2021 13:29
- Yamrt3
Replied by Yamrt3 on topic Float bowl gasket.
Will do. I guess it's installed wet after soaking. I'll go to the tech file now and find out the torque value for the srews for the bowl. Thanks for all your help. Hopefully I can start it in the next few days. One more thing, when I put the carb back on, the cylinder with the long needle that is attached to the throttle cable and goes into the carb, does it go in dry or with a little oil on it for lubrication since it slides up and down in that bore with the movement of the throttle?
12 Apr 2021 13:48
- 1971DT250
Replied by 1971DT250 on topic Float bowl gasket.
Be careful when tightening the float bowl screws. The bowl is brittle. Soaking the gasket in gas will help soften it. Don't be too agressive trying to stop it from leaking. Give it a day or 2 and snug the screws a little more. It's easy to crack the bowl mounts.
The slide tends to get some gas on it while running. I don't believe it's necessary to oil it before installing.
12 Apr 2021 14:04
- Yamrt3
That's exactly the info I needed. I'll be careful and follow that to the letter.
Gotta love this forum.
12 Apr 2021 14:19
Replied by MarkT on topic Float bowl gasket.
I've never pre-soaked a float bowl gasket. Must be someone else that recommended that? Not a bad idea though.
What I have said many times is don't worry about inital seepage if using an original Mikuni/Yamaha gasket. It can take a couple days but gas will swell up the gasket and the leak will stop.
12 Apr 2021 17:49
- Yamrt3
Someone mentioned that you did that and it makes sense so I'm going to do it. I read a lot of your posts and have used a lot of your info in this restoration of my RT3 with great success, so I'm not surprised someone thought that you did this gasket thing. Thanks Mark, keep the info coming, I use it all.
12 Apr 2021 18:01
