rt3 360 restoration help
Replied by MarkT on topic rt3 360 restoration help
Fixed it for you... we've all done it...
I usually use an air impact wrench... nut is right hand thread so normal counterclockwise rotation to loosen... I'd use a bigger pin like the actual piston pin and make sure both blocks are the same height.
28 Nov 2020 07:27
#21
- newbees
Replied by newbees on topic rt3 360 restoration help
thanks or the fix and advise just need a impct wrench and ill give it a go thanks
29 Nov 2020 02:11
#22
Replied by RT325 on topic rt3 360 restoration help
Yes, use a bigger solid bar through the rod eye but not a rough bar as don't want to damage the rod & block it so the crank bigend is about halfway up, so a good leverage point. I just use a socket & good handle. Not keen on air rattle guns when the big end is taking the strain, but just my personal preference. Might need an extension on the socket handle as it'll be 'tight'. Normal thread so standing behind the motor & pushing down on the handle.
29 Nov 2020 03:59
#23
- newbees
hello finaly got the crank nut of couldnt get a impact wrench so used the long bar and wedged the crank with wood thanks for that advise then onto the engine screws nightmare again 3 of them rounded and the little one on top of the engine shoker anyway managed get them out today, tried tapping engine and pulling apart but didnt seem to want to go i didnt try too hard in case ive not took something of so heres a couple pics of were i am is there anything else needs come of or should they split here sorry if youve told me before but this is all new to me thanks
06 Dec 2020 10:37
#24
- shyted
Replied by shyted on topic rt3 360 restoration help
Hello pal and welcome along.
To split the cases correctly you need a puller set and some form of heat. Yambits in York sell them.
Seriously you should read the manual over and over until you understand what it is your doing and how the force your applying is acting on what.
I think you can get an awful lot of insight into the job from watching Joe Greshes youtube 360 strip and rebuild so you can see what's going on .
joe is a member here too, in fact you can see his bike on the forum opening page. It's the pic of the guy putting fuel in his bike.
knowledge is power .
at the end of it , i would say be careful and don't brake anything. Some parts are very difficult to find here in the UK.
Regards Ted.
Regards Ted.
06 Dec 2020 12:13
#25
- yamahahaha
Replied by yamahahaha on topic rt3 360 restoration help
Can someone post a link for that video ? I was unable to locate it. Thanks
06 Dec 2020 14:00
#26
- Mothersbaugh
Replied by Mothersbaugh on topic rt3 360 restoration help
Not a video, but there must be something here:
yamaha-enduros.com/index.php/forums/sear...te=all&childforums=1
06 Dec 2020 14:33
#27
- RT360Fan
Replied by RT360Fan on topic rt3 360 restoration help
My guess is that it's this one...
The following user(s) Liked this Post: MarkT, shyted
06 Dec 2020 15:37
#28
- newbees
thanks for replys not had chance to get back on it yet hopefully weekend that videos is ace realy helpfull ended up buying another of ebay last weekend dont no why same condition maybee worse not picked up yet think im addicted
10 Dec 2020 12:19
#29
- apex
- Content Contributor
Replied by apex on topic rt3 360 restoration help
Take that nut off the countershaft before you start separating the cases!
Allrighty Then
10 Dec 2020 15:56
#30
