Dt250a , RT1 jet needles??
- KennyandtheJets
Dt250a , RT1 jet needles?? was created by KennyandtheJets
Hi guys been a while .. hope u all well.
Trying to find what stock needles and needle jets ran on these models . If anyone has that info be much appreciated.
I have a ported dt250a with race pipe running a 32mm carb off an rt1. It runs woefully bad in midrange . I think mismatched needle and jet is issue.
(Can’t seem to access the dt250a service manual I have used from the technical library before. )
When in doubt, power out !
12 Nov 2020 11:24
Replied by MarkT on topic Dt250a , RT1 jet needles??
There's a known issue with page 2 of the service manual listings... it's being difficult and attempts to fix haven't worked.
Here's a workaround link the should get you to the manuals on page 2:
yamaha-enduros.com/index.php/workshop/service-manuals?start=21
The following user(s) Liked this Post: KennyandtheJets
12 Nov 2020 11:57
- Pedalcrazy
Replied by Pedalcrazy on topic Dt250a , RT1 jet needles??
Sounds like maybe raise the clip on the slide needle one notch. Which will drop the needle slightly. Midrange problems are probably the clip position...easy to change and try again.
12 Nov 2020 15:12
- KennyandtheJets
Replied by KennyandtheJets on topic Dt250a , RT1 jet needles??
Running a dt250 needle in a rt1 needle jet probably not helping .. got em mixed up ..
The following user(s) Liked this Post: MarkT, Swoop56
12 Nov 2020 17:54
