ct3 speedometer
  • jtb605a
  • jtb605a's Avatar Topic Author
ct3 speedometer was created by jtb605a
Finally got my new cable for the speedo only to discover no cigar. Cable is spinning properly , put drive to spedo with drill and it only works when drill is spinning in reverse direction. Speedometer doen't won't to screw apart at top. Any suggestions ?
24 Sep 2020 15:57 #1
Replied by MarkT on topic ct3 speedometer
I'm pretty sure with every Yamaha speedo I've ever tried to spin with a drill, the drill had to be in reverse. That's normal.
So I'm not sure I understand the problem?
24 Sep 2020 16:09 #2
  • jtb605a
Replied by jtb605a on topic ct3 speedometer
If spinning in reverse direction with drill is correct why would my cable spin in the other direction when spinning the wheel forward ?
24 Sep 2020 16:34 #3
This kind of stuff makes my head hurt thinking about it so I need to see it.
It may be that you're facing the end of the cable and the drill is facing the back of the speedo?
Here's the best way I can describe...
Speedo needle swings clockwise when looking down from top like normal....
Cable has to spin the same direction when looking down on end of cable that connects to back of speedo...
Make sense so far?
When you hold your drill with the chuck facing towards you, like it is when connected to the wheel end of the cable, it must be in reverse to spin the cable and therefore the speedo clockwise.
As far as what's happening with your wheel, is your front brake plate with speedo cable on the left side of the bike when sitting on the seat facing forward? Could you be spinning the wheel backwards by mistake? (easy to do)
Pictures and/or video of what you're seeing would be very helpful if the above doesn't make sense.
The following user(s) Liked this Post: HouseofEnduro
24 Sep 2020 16:51 #4
  • jtb605a
When spinning the wheel forward the cable spins in opposite direction of speedometer needle. yeah, making my head hurt too.
24 Sep 2020 18:33 #5
Detailed pictures of your front wheel might help.. maybe somebody installed wrong parts or installed parts wrong.
24 Sep 2020 18:37 #6
  • jtb605a
Ah ha ! Someone has changed the fork tubes and put the brake hub side on the right. (sitting on the bike) this explains everything. I never owned one of these before and didn't catch it, thanks for the help.
24 Sep 2020 18:48 #7
