Ct1 175, 1970 ..front wheel spacer
- Pete-RT1
Replied by Pete-RT1 on topic Ct1 175, 1970 ..front wheel spacer
Ht1kid, not sure what spacer you have but part number is 183-25183-00 is 12mm id x 18mm od x 16mm long.
As soon as you said 12mm long, it didn't sound right to me.
Here's a parts list from a YAS1C which uses the same part and has the dimensions of the part with it.
https://
https://
Yamaha CT3 (in bits)
Replied by Ht1kid on topic Ct1 175, 1970 ..front wheel spacer
Hey Pete item 33 #90387-12095-00 according to my listings. I think between me and you he should be good if not we will figure it out
i.imgur.com/Ilde4Bu.jpeg
If I need to I can pop the seal out
- Pete-RT1
The Yamaha parts list calls for 183-25183-00. I see the alternative part listed 90387-12095-00 on CMSNL and I see a photograph of it.
Looking at the 18mm diameter it certainly looks about 16mm long.
Htikid, not sure what popping the seal out will show us.
Do you have a photograph of your spacer showing the length?
05 Jan 2025 15:43
#14
i.imgur.com/H9RlKF3.jpeg
i.imgur.com/O0zguD9.jpeg
#33 collar is pressed into #32 dust cover. Pete I saw my mistake when I pulled the seal out it was the bearing that was measured good catch.
The following user(s) Liked this Post: MarkT, Pete-RT1
05 Jan 2025 17:52
#15
- Pete-RT1
Glad we've sorted it out, I was starting to question myself and would have probably pulled a front wheel to check.
Out of interest, is that the '71 parts list from the tech library? I used the '69-'71 parts list as we were looking for the '70 model.
Hey Pete no I copied mine from a local Yamaha dealer here years ago
06 Jan 2025 06:33
#17
- Joe1028
Replied by Joe1028 on topic Ct1 175, 1970 ..front wheel spacer
Easy enough to make another one...i thought 12mm(aprox 1/2") seemed to short..
thanks guys for all the help...
17 Jan 2025 19:25
#18
Replied by RT325 on topic Ct1 175, 1970 ..front wheel spacer
The split spacer clamped in the steel sliders of those early yamahas has a bit of give & take i think without going to look at mine. So providing the clamp is slightly loosened the split thingy will just find its place against the spacer you're making so i'm theorizing that it wouldn't matter if its shorter or longer by a mm or two--or three. Within reason.
