Ct1 175, 1970 ..front wheel spacer
  • Joe1028
  • Joe1028's Avatar Topic Author
Ct1 175, 1970 ..front wheel spacer was created by Joe1028
Hi All.
  .missing the front wheel spacer that rides in hub seal.i just need a dimension so I can make one.. overall length of spacer. 1970 ct1 175....
Joe
Last edit: 05 Jan 2025 14:01 by Joe1028.
04 Jan 2025 17:21 #1
Replied by Schu on topic Ct1 175, 1970 ..front wheel spacer
I should be able to measure overall length and outside diameter easy enough. Stay Tuned Joe!
Edit:
oh wait….it fits into the seal so I would have to pull the axle back and remove the spacer. And it’s really cold in my barn right now. Let’s see if anyone happens to have one loose in hand for measurements. If not, I’ll get’r done for you.
Last edit: 04 Jan 2025 18:42 by Schu.
04 Jan 2025 18:39 #2
Replied by Ht1kid on topic Ct1 175, 1970 ..front wheel spacer
Joe the width is 15.72 mm length is 45.66 mm
05 Jan 2025 08:13 #3
  • Joe1028
Replied by Joe1028 on topic Ct1 175, 1970 ..front wheel spacer
Haha....I hear you, another person did reply so no need to freeze yourself....Thanks!
Have a good one Joe...
05 Jan 2025 10:02 #4
  • Joe1028
Thanks Ht1kid for dimensions...This will make it easier..
05 Jan 2025 10:04 #5
Replied by Pete-RT1 on topic Ct1 175, 1970 ..front wheel spacer
Joe, might be worth confirming which part are you talking about?
I read it that you are talking about item 33 which will be 18mm diameter based on the seal, not sure of length without removing a wheel.
I think the dimensions Ht1kid has given you are for the bearing spacer (item 7), which could be what you are talking about.
https://
Yamaha CT1 007
Yamaha CT1-B The Doppelgänger
Last edit: 05 Jan 2025 10:43 by Pete-RT1.
05 Jan 2025 10:43 #6
Ha. Good point Pete.
I probably would've measured item 36.
05 Jan 2025 11:07 #7
Item 33 is 12mm long I have a front wheel off at the moment
05 Jan 2025 13:45 #8
  • Joe1028
Hi guys,
yes 33 the spacer that rides in the wheel seal..I have the longer split spacer.
thx, joe
05 Jan 2025 13:54 #9
  • Joe1028
Thanks Sir....
05 Jan 2025 14:12 #10
