What is the number printed on the outside of some NOS cylinder bores?
- amsbstn
What is the number printed on the outside of some NOS cylinder bores? was created by amsbstn
Hello! I have noticed a number (like .005) factory printed on the outside of some nos Yamaha 2 stroke cylinders. By outside, I mean the outside of the cylinder skirt. I'm wondering if anyone knows what this number means? Is it a factory QA tolerance or something? Just a mystery (to me) that I thought someone on this forum may have the answer to.
Thanks!
-Adam
Thanks!
-Adam
04 Feb 2024 09:10
Replied by MarkT on topic What is the number printed on the outside of some NOS cylinder bores?
My opinion is it's the deviation from the standard bore size. For example if standard bore was 66mm, a "000" cylinder would be 66mm.
A "005" would be 66.005mm. (I believe I've seen a negative number as well)
Standard pistons were made in incremental sizes such as 65.960 and 65.965. The correct piston then could easily be chosen to get the clearance correct.
The following user(s) Liked this Post: Ht1kid, Badrul, cranky_dave
Oh, I based the above opinion on disassembly of engines that still had the ink stamp legible and the original piston installed... plus I have had a couple of NOS cylinders and was able to measure them.
The following user(s) Liked this Post: Ht1kid, msavitt, Badrul, cranky_dave
04 Feb 2024 12:40
