Fork shrouds
  • Andrew60
  • Andrew60's Avatar Topic Author
Fork shrouds was created by Andrew60
Hi could anyone enlighten me how to remove chrome shrouds in dt1.250 1971 thanks
16 Feb 2022 11:16 #1
Replied by RT325 on topic Fork shrouds
Wonder if you could squirt some CRC-5-56 or penetrating oil of some type down in past the fork tube from the top to help out. The ribs on the rubber bits might stop it getting down all the way though. Thinking back 50 years is there a very small hole in these chrome bits near the base to squirt in. I just used to get brutal with mine & wrap with emery tape then make them move but not good for a mint resto job so someone will have a better idea. Fork tubes can come out & leave those parts behind so not sure if it'd be easier minus the internals. Just the Allen Key bolt in the base but that'll be another story as the damper will want to turn & give you grief--but hope ya lucky.
16 Feb 2022 14:17 #2
  • Andrew60
Replied by Andrew60 on topic Fork shrouds
Thanks rt35 Just wondering if they are threaded ?
16 Feb 2022 14:54 #3
Replied by 1971DT250 on topic Fork shrouds
They are not threaded. After 50 years the rubber becomes one with the chrome cover and upper part of the lower fork tube. It's easy to damage the chrome cover and the upper part of the lower fork tube, very thin and brittle. Penetrating oil, moderate heat from a hair dryer and patience. Use a rubber strap oil filter wrench.
The following user(s) Liked this Post: MarkT, RT325, Andrew60
Last edit: 16 Feb 2022 15:20 by 1971DT250.
16 Feb 2022 15:17 #4
Now that's a better idea above.
16 Feb 2022 19:04 #5
  • Andrew60
Thank you much appreciated
17 Feb 2022 00:19 #6
