setter needle jet
Replied by Gr8uncleal on topic setter needle jet
Did you check the tiny jet in the float bowl?
17 Dec 2024 00:35
#21
- jsmith6752
Replied by jsmith6752 on topic setter needle jet
not yet the bike is being looked at for electrical problems but I will check it for sure thanks
17 Dec 2024 05:55
#22
- Swoop56
Replied by Swoop56 on topic setter needle jet
There are two different Jet Setters , the difference being the thread pitch , which needs to match your needle jet in your carb .
If it doesn't screw into the Needle Jet easily , you have the wrong one . The pitch difference is small so even the wrong Setter will probably start
threading into the Needle Jet , but will bind up quickly .
17 Dec 2024 11:14
#23
Replied by RT325 on topic setter needle jet
I 'think' & 'happy to be corrected' that #19 is just saying if you find an Oring that fits snug in the grove but is too fat--sticks out too far--just sand the outer Oring edge.
All good but Gotta be careful doing that.
Like maybe stretch it over a long bolt & revolve it against a sanding wheel or something.
It's the sort of thing i'd do if i was stuck.
Once i simply sat an Oring of some sort out of the groove & let it sit up to the hex & it sealed down in the lead in to the bowl cavity.
Still had the old Oring in its groove too.
But don't follow me as i do dodgy stuff sometimes!!.
Correct Oring should be easy to find, as in post #15 if we're talking DT360A--forgotten where we're at now. It's old age you know lol.
- jsmith6752
I did purchase the OEM o ring thanks
17 Dec 2024 18:47
#25
- jsmith6752
screwed in very easy I got the correct one thanks
The following user(s) Liked this Post: RT325, Swoop56
17 Dec 2024 18:48
#26
- bluntz465
Replied by bluntz465 on topic setter needle jet
So its running smoothe now we assume?
1982 Yamaha IT465J
1982 Yamaha IT465J
20 Dec 2024 15:57
#27
- jsmith6752
I actually don't have the bike right now. I took it to a guy to fix the bird nest inside the headlight. I have a new rebuild carb kit I will install when I get it back.
21 Dec 2024 06:42
#28
- jsmith6752
is that jet in the bowl removable?
The following user(s) Liked this Post: automan
28 Dec 2024 15:27
#29
No.
28 Dec 2024 22:42
#30
