setter needle jet
- jsmith6752
setter needle jet was created by jsmith6752
DESPERATELY seeking a setter needle jet for a DT360. It's the piece that the needle jet on the slide that goes into it. Would be willing to buy a junk carb to get one
thanks
thanks
16 Dec 2024 07:44
Replied by Gr8uncleal on topic setter needle jet
16 Dec 2024 07:48
- jsmith6752
Replied by jsmith6752 on topic setter needle jet
that's it but is it for a DT360? I bought one like it but it not sure it's the correct one having trouble starting
16 Dec 2024 07:54
- jsmith6752
different part number need 137-14153-00-00
16 Dec 2024 07:56
"different part number need 137-14153-00-00"
That part is the washer - see link.
WASHER,MAIN JET for DT360 1974 USA - order at CMSNL
If you have a genuine, correct 1974 DT360A, then I believe that my first post showed the correct part.
360 models up to 1971 were RT1, 1972 was RT2 and 1973 was RT3 - only the 1974 model was called a DT360.
- jsmith6752
partzillow might be wrong or is it me?
16 Dec 2024 08:10
- jsmith6752
partzillow might be wrong or is it me? 13714145-00-00
16 Dec 2024 08:15
Partzilla is wrong, I believe. I have an original paper parts book and it shows what I posted.
Hard starting could be due to the tiny fixed brass jet in the float bowl being blocked.
I have attached a link to an image of a random float bowl to show what I'm referring to.
BODY, FLOAT CHAMBER for DT100 1975 USA - order at CMSNL
Along the edge of the float bowl nearest to you as you look at the photo is a hollow casting and this exits into the bowl via a tiny jet. If you spray a little carb cleaner, or other non harmful fluid, down into the casting, you should see it exit via the jet - if it doesn't, then the jet is blocked and that is your problem.
If it is blocked, I have had success clearing blocked ones with a length of 0.4mm copper wire - others here have used old guitar strings!
The following user(s) Liked this Post: Sneezles61, 2strokenewb
- automan
Replied by automan on topic setter needle jet
Are you missing the setter?
They all look the same to my 45 years doing these.
Just a big ole hole connecting NJ to bowl for the MJ in bowl transition.
cliff
cliff
16 Dec 2024 09:26
Replied by MarkT on topic setter needle jet
Didn't you already get a new jet setter recently?
16 Dec 2024 09:46
