setter needle jet
  • jsmith6752
  • jsmith6752's Avatar Topic Author
setter needle jet was created by jsmith6752
 DESPERATELY seeking a setter needle jet for a DT360. It's the piece that the needle jet on the slide that goes into it. Would be willing to buy a junk carb to get one
thanks
16 Dec 2024 07:44 #1
16 Dec 2024 07:48 #2
  • jsmith6752
Replied by jsmith6752 on topic setter needle jet
that's it but is it for a DT360? I bought one like it but it not sure it's the correct one having trouble starting
16 Dec 2024 07:54 #3
  • jsmith6752
different part number need 137-14153-00-00
16 Dec 2024 07:56 #4
Replied by Gr8uncleal on topic setter needle jet
"different part number need 137-14153-00-00"
That part is the washer - see link.
WASHER,MAIN JET for DT360 1974 USA - order at CMSNL
If you have a genuine, correct 1974 DT360A, then I believe that my first post showed the correct part.
360 models up to 1971 were RT1, 1972 was RT2 and 1973 was RT3 - only the 1974 model was called a DT360.
Last edit: 16 Dec 2024 08:07 by Gr8uncleal.
16 Dec 2024 08:06 #5
  • jsmith6752
partzillow might be wrong or is it me?
16 Dec 2024 08:10 #6
  • jsmith6752
partzillow might be wrong or is it me? 13714145-00-00
16 Dec 2024 08:15 #7
Partzilla is wrong, I believe. I have an original paper parts book and it shows what I posted.
Hard starting could be due to the tiny fixed brass jet in the float bowl being blocked.
I have attached a link to an image of a random float bowl to show what I'm referring to.
BODY, FLOAT CHAMBER for DT100 1975 USA - order at CMSNL
Along the edge of the float bowl nearest to you as you look at the photo is a hollow casting and this exits into the bowl via a tiny jet. If you spray a little carb cleaner, or other non harmful fluid, down into the casting, you should see it exit via the jet - if it doesn't, then the jet is blocked and that is your problem.
If it is blocked, I have had success clearing blocked ones with a length of 0.4mm copper wire - others here have used old guitar strings!
The following user(s) Liked this Post: Sneezles61, 2strokenewb
Last edit: 16 Dec 2024 08:31 by Gr8uncleal.
16 Dec 2024 08:28 #8
Replied by automan on topic setter needle jet
Are you missing the setter?
They all look the same to my 45 years doing these.
Just a big ole hole connecting NJ to bowl for the MJ in bowl transition.
cliff
16 Dec 2024 09:26 #9
Replied by MarkT on topic setter needle jet
Didn't you already get a new jet setter recently?
16 Dec 2024 09:46 #10
