1979 IT 400 restoration
Replied by RT325 on topic 1979 IT 400 restoration
looks like they long stroked the "79IT like they did with the YZ in "79 one year only. So "79 is 82mm. YZ "79 piston is a 2X5 number so worth checking out & has the "Go Fast" big cut away on the inlet side but just might match up in other respects. I run one of these in my overbored RT2--80mm out to 82mm.
Pay to measure yours just to be sure to be sure using verniers across it best you can as difference between 82 & 85 should be easy to see.
Replied by MarkT on topic 1979 IT 400 restoration
Again, check with Enduronut if you haven't already.
10 Jan 2023 15:33
#22
Replied by Ht1kid on topic 1979 IT 400 restoration
I have a question since we are talking pistons MarkT or Enduronut would probably know I see pistons on eBay and remember 50yrs ago seeing Rocky pistons and just wondering who made them for Rocky, Art Brand, Hap Jones ? Just curious?
- GaryInVA
Replied by GaryInVA on topic 1979 IT 400 restoration
Message has already been sent. Thanks again.
- GaryInVA
This is how far I've been able to get the piston to move soaking in Kroil and then using a wooden dowel and rubber mallet to move. How close does this look to BDC? Will it move down any more? I guess I need to pull the cylinder studs this weekend and see if I can jack the cylinder up some and then pound the piston out more.
11 Jan 2023 07:48
#25
- msavitt
Replied by msavitt on topic 1979 IT 400 restoration
nice work, not too bad IMO
can you get to the wrist pin?
my thought here is that if you could get pin out you can get piston/cylinder on your bench making removal easier without risk of messing up big end, etc.
11 Jan 2023 10:42
#26
Replied by Gr8uncleal on topic 1979 IT 400 restoration
Have a look on my post #24 on this thread to see what I did with my GT550.
Incoming ….. The Brave Pill - Page 3 - Vintage Enduro Discussions (yamaha-enduros.com)
11 Jan 2023 10:51
#27
- GaryInVA
I haven't pulled the nuts off the studs to mount the cylinder to the cases yet. This weekend I'm also going to pull the left side case to see if the flywheel area is corroded.
11 Jan 2023 11:20
#28
Just pull the stud nuts & smack around the cylinder with a block of wood across multiple fins & hammer to free the gasket. Then turn the crank the oposite way--whichever 'that' is--& it'll lift the cylinder. Either way might do if at true BDC. Force the mag flywheel that is. Then block it & keep driving. What a damn shame--crying shame really & so easily avoided.
Look through the pics on this link of mine if it works. Had a very similar situation. My saying 'is' she'll be running by lunchtime--& nearly was haha.
yamaha-enduros.com/index.php/forums/the-...n-at-it-again#139199
11 Jan 2023 12:13
#29
- AirborneSilva
Replied by AirborneSilva on topic 1979 IT 400 restoration
Morely, you need to change your forum name to "2 stroke motor whisperer" you get motors running that just shouldn't!!!
The following user(s) Liked this Post: Ht1kid, Andy L
11 Jan 2023 13:05
#30
