1971 CT1 Points/Flywheel Question
  • mk2020
  • mk2020's Avatar Topic Author
Replied by mk2020 on topic 1971 CT1 Points/Flywheel Question
Thanks MarkT! An incorrect flywheel was my first assumption too, and I bought another supposed CT1 Flywheel on ebay. The replacement flywheel has all the same measurements as the first one and fits in the same way. It does seem possible that I ended up with 2 of the same wrong flywheel form another similar bike.
Here are some measurements for the flywheels that I have.
OD: Approx 120mm
Depth of cam lobe from top of taper collar: Approx 20mm
I'll attach some images of the measured flywheel. Sorry for the inch calipers - I don't have any in metric.
Both flywheels that I have are marked Hitachi F-130
Last edit: 18 Dec 2018 12:28 by mk2020.
18 Dec 2018 12:26 #11
Replied by RT325 on topic 1971 CT1 Points/Flywheel Question
Wow the plot thickens. CT2 & CT3 had smaller OD flywheels. People advertise everything often as CT1 because CT1 numbers still go to the end of 1973 CT3 & prefix is still called CT1. Now i don't suppose you got a CT3 flywheel. In saying that i wouldn't have thought the cam would be any different. But as i understand it 'now' the cam doesn't sit deep enough which is a whole new ball game. CT1 flywheel is noticeably heavier than the 2 & 3. In saying 'that' i'm not sure if they're Hitachi all the way to "73 or something else like ND. MarkT would know. Might get to my AT1 & read the number off the flywheel. ---& measure diameter.
18 Dec 2018 13:31 #12
  • mk2020
A real mystery indeed!
The flywheel weights 1.3 kg if that means anything to anyone.....
18 Dec 2018 14:54 #13
Yes my flywheel on my "70 AT1 is an F130 Hitachi. Trying to get as near as i can lining the metric verniers up through the cover it looks 116mm but might be a fraction out--same flywheel anyway.
18 Dec 2018 16:37 #14
Rendering Error in layout Message/Item: fopen(http://open.api.ebay.com/shopping?callname=GetSingleItem&appid=makotosu-08bc-47da-8e7d-68e3ee6e51ca&siteid=0&responseencoding=JSON&ItemID=332620247642&version=889&trackingid=&trackingpartnercode=9): failed to open stream: php_network_getaddresses: getaddrinfo failed: Name or service not known. Please enable debug mode for more information.
Replied by MarkT on topic 1971 CT1 Points/Flywheel Question
Okay, found 2 CT1 F130 Hitachi ignitions... both the same.
Some pictures:
Stator
Inside of flywheel:
Flywheel on stator from back side. Note that the points cam is almost flush with the stator plate.
I measured a little differently... ~31mm from flange surface to top of points cam.
18 Dec 2018 18:49 #16
I have some more pictures but I think I understand the misunderstanding...
The points cam is a VERY subtle "bump" in the approximate area in the pic below.
The actual points cam is the area marked by the arrows, not the area marked with the X in the picture below.
18 Dec 2018 18:55 #17
Some other measurements... the ID of the tapered hole is about 19.5mm inside the flywheel and 14.2mm outside the flywheel.
The depth of the flywheel is about 37mm:
The points cam starts about 3mm or 4mm below flush from the rim of the flywheel
Hope this info helps!
18 Dec 2018 19:03 #18
  • mk2020
Well MarkT, you are officially the man! I was looking at the flywheel all wrong. Looking from the top, I was convinced that the little lip below the points cam was the cam. Total optical illusion I guess. Turns out the only wrong part was me.... I set the points, and I got a fat blue spark.
I can't thank you guys enough. Feeling like and idiot over here, but you just saved me from an endless goose chase.
The following user(s) Liked this Post: MarkT, asco
18 Dec 2018 20:09 #19
I'll sleep tonight lol--already past midnight. Top Marks to MarkT.
19 Dec 2018 03:24 #20
