Manual Compression Relief Valve for the ankle breaking RT1
  • YAMABOBINTEXAS
  • YAMABOBINTEXAS's Avatar Topic Author
Rendering Error in layout Message/Item: fopen(http://open.api.ebay.com/shopping?callname=GetSingleItem&appid=makotosu-08bc-47da-8e7d-68e3ee6e51ca&siteid=0&responseencoding=JSON&ItemID=311298246684&version=889&trackingid=&trackingpartnercode=9): failed to open stream: php_network_getaddresses: getaddrinfo failed: Name or service not known. Please enable debug mode for more information.
Yep I received it and thank you for the links.
15 Apr 2016 07:23 #12
  • KennyandtheJets
  • KennyandtheJets's Avatar
  • Platinum Member
  • Platinum Member
:likey Nice. Keeps the handle bars tidier . May I ask by what mechanism does it close ?
When in doubt, power out !
17 Apr 2016 00:24 #13
  • YAMABOBINTEXAS
Not really sure what you're asking. It relieves some of the compression in the combustion chamber when you kick it over, then reseats itself when if fires.
YAMABOB
18 Apr 2016 06:24 #14
Thanks for providing the details. :OnFire
Did the RT1M come with the stock - Decompression Valve setup.
Did you use this as your 'only ' Decompression Valve or along - with
the Stock (handlebar valve) setup?
Thanks again,
c.winterwoods
Last edit: 18 Apr 2016 06:57 by Winterwoods.
18 Apr 2016 06:56 #15
  • YAMABOBINTEXAS
Did not come with any kind of compression release. This set up was just an add on I came up with to use.
YAMABOB
The following user(s) Liked this Post: Winterwoods
18 Apr 2016 07:08 #16
the 1970 RT1M and 1971 RT1MX did not come with a compression release from the factory. of course I have a 1970 RT1M but I have also a 1971 RT1MX engine. the place on the cylinder for the compression release is blanked off and is not drilled and tapped for the factory one to be installed.
Dave
Jesus is Lord!
Last edit: 18 Apr 2016 08:46 by Bigdog302.
18 Apr 2016 08:45 #17
  • KennyandtheJets
  • Platinum Member
  • Platinum Member
It's a super tidy unit. I was just wondering how it resets itself . I asked the seller the same question on eBay and the response was "push and pull manually " .
Just wondering how a contraption designed to release pressure also closes with pressure ..
19 Apr 2016 02:59 #18
Sounds like you might have to dissect one to see how & what it's built from
Watching this th'd closely.... :Coffee
1974 DT250A
1974 DT250A
1977 IT175D "Alex"
1978 IT175E
1972 DT2 "Adam"
1973 DT3
"And there ya have it"
19 Apr 2016 05:21 #19
The high pressure of combustion acting on the valve head does the "pull manually" job to close the valve for you if that makes any sense.
That's why Bob said you have to keep checking (and possibly re-pushing) the button after a failed kick start attempt.
19 Apr 2016 06:11 #20
