Manual Compression Relief Valve for the ankle breaking RT1
  • YAMABOBINTEXAS
  • YAMABOBINTEXAS's Avatar Topic Author
MarkT answered the question exactly. It closes when there is excessive compression pushing against the face of the valve. Like when ignition and combustion occurs. Thanks MarkT. If it does not start, you depress the valve again and keep trying until the motor starts and runs. The manual. The manual portion or the procedure only has to do with depressing the valve which allows some compression to escape through an orifice in the valve. Once internal pressure is great enough to override the valve spring pressure, the valve closes and seats.
YAMABOB
19 Apr 2016 07:54 #21
That is the condition that you want to control.
Ignition/Combustion, with - No Start.
In this case, the Cylinder Vents and closes the Valve(UP).
With, no start -
Manually push the button(DOWN) and crank, again.
That is how I understand the workings.
Works the same as the Stock Decompression Valve,
except that one remains - Open or Closed, until the
lever position is moved.
c.winterwoods
Last edit: 19 Apr 2016 08:53 by Winterwoods.
19 Apr 2016 08:50 #22
I installed this on my daily rider RT3 which will let me know who's boss when I kick start it. Made a big difference. Makes me believe the decomp valve or hole in the the cylinder is plugged.
Also put a small piece of foam around the body of it to keep it clean.
13 May 2016 04:04 #23
Please send me the link to decompression devise you purchased for DT360 on site or my
e-mail is This email address is being protected from spambots. You need JavaScript enabled to view it.
18 Feb 2022 08:13 #24
For the adapter search Alloy Art CRA-1 on eBay.
For the decomp valve I use Harley Davidson part # 32076-04. Available from your local dealer.
18 Feb 2022 10:18 #25
18 Feb 2022 11:34 #26
