Wiseco piston rings
- Dugadie9
Wiseco piston rings was created by Dugadie9
Greetings, would a 1860c wiseco piston ring size 47.25 1st over fit into a 1981 Yamaha piston 47.25 1st over ?? Appreciate it I’m hearing they may fit ??
thanks
thanks
30 Sep 2025 12:30
Replied by MarkT on topic Wiseco piston rings
You can ask the same question a different way, but my answer is still "no".
Piston rings need to match the groove and Wiseco generally used flat thin steel rings and Yamaha used thicker iron rings, often with a "keystone" taper.
Fitting an incorrect ring to a piston can result in disaster and serious damage to the engine after very little running. Don't ask me how I know but it involved a Yamaha 80 I had as a kid and using rings that weren't correct for the piston.
30 Sep 2025 13:38
- Dugadie9
Replied by Dugadie9 on topic Wiseco piston rings
Appreciate you Mark. It’s a shame I can’t find a piston ring part # 2A4-11610-10-00
would you know where I can get these 2-rings set ?? I’ve searched the internet can’t seem to find them ??
30 Sep 2025 13:49
I'll send you a pm with some contact info for the "best bet" I can think of.
30 Sep 2025 16:33
