DT360 throttle cable
Replied by MarkT on topic DT360 throttle cable
Jsmith here is the link to the HVC Cycle cable because I know from previous posts on other topics you've made that you might not have even looked at it or feel it should be cheaper or something.
hvccycle.net/yamaha-dt250-dt360-dt400-th...-cable-437-26311-02/
Cables are not "rocket science" and easy to build as well, especially if you only need a piece or two.  But that seems to be a lost art.  Flanders, Motion Pro or others have parts...  some of the fittings like the oil pump elbow into the case would have to be reused from your old cable.
And as I've said, there are shops that will build you a new one if you supply them the old cable.
Good luck and thanks for not starting 42 different new topics for this same question this time.
The following user(s) Liked this Post: Swoop56, Snglsmkr, pabdt, Ht1kid
10 Jan 2025 06:11 #11
  • jsmith6752
  • jsmith6752's Avatar Topic Author
Replied by jsmith6752 on topic DT360 throttle cable
Just got off the phone with a Yamaha dealer. I am in need of a throttle cable that goes from the splitter to the cab on a 74 DT360.He was able to give me 3 part numbers but they are listed by number. I was not able to give me the one I needed because he did not have a diagram. If anyone has a good drawing please let  me know...thanks
500-26312-02-00 part numbers
437-26311-02-00
500-26312-02-00
10 Jan 2025 12:44 #12
Replied by pabdt on topic DT360 throttle cable
A while back, I posted the dimensions of a DT 360 cable. I also have an HVC Cable. The lengths are the same for the cable housing and while I did not actually measure the internal cable, they looked the same.
DT360 CABLE that I believe to be OEM.
________________________________________________
1969 Yamaha CT1 175
1974 Yamaha DT125A
10 Jan 2025 16:45 #13
Replied by Swoop56 on topic DT360 throttle cable
Two of your three part numbers are identical , and they are both for a DT 400 B/C .
The numbers you need for your 360 are 437-26311-01 ( throttle to splitter )  and
438-26312-01 ( splitter to carb & pump ) .
They may supercede to the 400 numbers , I haven't checked .
10 Jan 2025 17:20 #14
JSmith,  I combined your brand new thread about the cable with the same exact topic here.
10 Jan 2025 18:03 #15
  • jsmith6752
I just spoke with Motion Pro about getting my lower throttle cable replaced  for my DT360. Wow, sticker shock. 19" cable will be $180. Does anyone know of a different vendor for this? thanks
13 Jan 2025 12:07 #16
  • jsmith6752
HVC Cycle has a similar cable but the carb end look different. I will try to post a pic of mine.
13 Jan 2025 12:13 #17
  • jsmith6752
13 Jan 2025 12:25 #18
Replied by treeves on topic DT360
I bought the complete throttle cable from HVC for 65 dollars. I have been using it for a couple of years on my Dt 360 with no problems.
13 Jan 2025 16:23 #19
JSMITH, please post the cable end pic and the top and bottom of the chamber/slide cap on the carb where the cable was attached. Should have been a C-Clip holding the 45" tube in.
1969 Yamaha CT1 175
1974 Yamaha DT125A
14 Jan 2025 01:28 #20
