New old guy working on a DT360
  • 2strokenewb
  • 2strokenewb's Avatar Topic Author
Replied by 2strokenewb on topic New old guy working on a DT360
Update-It starts, idles, and revs, but rev is kinda slow. Do these have a centrifugal advance mechanism? I put a chain on it, and rode it up and down the block twice, hoping the smoke would clear out. This things smoked like a locomotive. Maybe it's because of the premix I put in the tank...
Maybe it's a crank seal too, or the exhaust is full of oil?
I took the dipstick out while it was running and the RPM went super high, so I stuck it back in. Would a bad crank seal make it do this? or is that what happens on a running 2 stroke when the crankcase is opened up while running. My gut tells me something is amiss there.
27 Nov 2024 18:34 #11
Replied by MarkT on topic New old guy working on a DT360
Would a bad crank seal make it do this?   YES
The following user(s) Liked this Post: 2strokenewb
27 Nov 2024 19:07 #12
  • 2strokenewb
So should I start with the right side? are both left and right seals something I can change without scattering the entire engine?
I was hoping it was just too much oil with the premix and the autolube, but the way that idle took off when I pulled the dipstick... I've never seen an engine do that
27 Nov 2024 19:50 #13
Replied by pabdt on topic New old guy working on a DT360
2strokenewb, this is my DT360, right side cover removed.
Right Side Cover Removed:(note, this is during disassembly; new basket case has been installed for those that note it is broken)
Crankshaft drive gear and seal. To remove, stick a rag between the drive gear and clutch gear. I use an impact.
1969 Yamaha CT1 175
1969 Yamaha DT1S 250
1974 Yamaha DT125A
The following user(s) Liked this Post: MarkT, Ht1kid, 2strokenewb
Last edit: 28 Nov 2024 02:17 by pabdt.
28 Nov 2024 02:15 #14
Note, the seals on the FAR RIGHT are the "castle" seals and the good ones.
1969 Yamaha CT1 175
1974 Yamaha DT125A
Last edit: 28 Nov 2024 02:30 by pabdt.
28 Nov 2024 02:29 #15
  • 2strokenewb
So, the rag will prevent the crank gear from turning the clutch basket? I can do this with the clutch basket in place?
I tried to buy those seals, but seller is on break until Friday
Thanks all, for the looks and responses
28 Nov 2024 05:05 #16
Replied by Schu on topic New old guy working on a DT360
I had the same issue with both of my DT360As. The link below may be helpful. Start at post #54 thru #60. Good luck!
www.yamaha-enduros.com/index.php/forums/...ish-me-luck?start=50
The following user(s) Liked this Post: MarkT, pabdt, Ht1kid
28 Nov 2024 08:02 #17
Two stroke crank seals must seal pressure and vacuum...  original seals are "SW" type with two spring-loaded seal lips that accomplish this... basically two seals in one.
The plethora of "inexpensive" seals on ebay are "SD" seals with one spring loaded lip...  the second seal lip is a rudimentary "dust seal" and does not have a spring.  While these seals might work "okay", they generally will never seal as well or as long as original type.
Castle turret bumps on original seals are there to prevent pressing them in too far and restricting the oil to the main bearings.  The seal lips themselves on original seals are specially coated to be low friction and last a long time in the harsh environment.
There are MANY reasons to go with OEM SW seals!  The drawback is they can be harder to find and sell for about $45 each on ebay.  The others are about $30 for both on ebay...  and even less at a bearing supply house.
Both OEM seals were available on ebay when I just checked.
And yes, basket MUST be removed.  Pay careful attention to the way the discs and thrust washers are installed!!  Take pictures!  Do NOT rely on exploded parts diagrams to assemble as they are not correct in most cases.  And use an inner clutch hub holding tool when loosening the nut.  Never try to hold the inner basket with the outer basket unless you want to buy a new outer basket after you break off an ear or two.
I would also suggest an air or electric impact for the crank nut...  remember to loosen before removing clutch. I've shredded rags and destroyed pennies trying to wedge the gears and remove the nut without an impact gun.
The following user(s) Liked this Post: pabdt, Schu, Ht1kid, 2strokenewb
28 Nov 2024 08:37 #18
  • 2strokenewb
Thank you Mark, for the well explained post. I found the NOS seals on ebay and bought them as well as gaskets for both sides. Isn't there also some sort of oring for the kicker shaft hole?
I have both electric and air impacts
I do not have the tools for the clutch basket removal. Can I buy these? any recommendations on what to get and what to avoid would be greatly appreciated
It's cleaning up nicely considering it sat abandoned for so long
Last edit: 28 Nov 2024 11:26 by 2strokenewb.
28 Nov 2024 11:21 #19
The fuel and oil tanks on that bike look great.
For reference:
Clutch Basket Tool:
www.amazon.com/gp/product/B09LYGT9Q8/ref..._title?ie=UTF8&psc=1
Kick starter Seal:(no orings except on the crank gear where main seal is I recall an oring there)
www.partzilla.com/catalog/yamaha/motorcy.../dt360a/kick-starter
1969 Yamaha CT1 175
1974 Yamaha DT125A
28 Nov 2024 13:18 #20
