DT 175 A carb ?
- jez
DT 175 A carb ? was created by jez
Hi Guys, i have just got a new project and i need a carb for it . the bike is a 1974 DT 175 model A , how do i find out the details for the carb that is for this bike ?any help would be great . cheers....
16 Jan 2023 07:54
- AirborneSilva
Replied by AirborneSilva on topic DT 175 A carb ?
Look in the tech library at the top of the page, you can find a shop manual that will give you all the specs for your bike, might be able to download an owners manual too.
16 Jan 2023 08:00
- jez
Replied by jez on topic DT 175 A carb ?
how do ya match the carb number to the bike is it stamped in carb somewhere ??
19 Jan 2023 07:44
Replied by Gr8uncleal on topic DT 175 A carb ?
Check out this one - you can see the number stamp in the second photo.
If I can't get hold of an original parts manual for a bike (usually a pdf download from a forum like this one), then I use CMSNL or Partzilla for part number look ups.
Yamaha DT175 Mikuni 27mm carb '443' 1974 443-14101-62-00 needs cleaning MX100 | eBay
Yamaha DT175 1974 USA CARBURETOR - buy original CARBURETOR spares online (cmsnl.com)
19 Jan 2023 08:07
- jez
Thanks for your reply, i have just got this bike as a restoration project it is a 1974 DT 175 model A . it didnt have the carb on it but i found it in a bag of parts so wanted to confirm it was from this bike .it looks identical to the one in the link although the number is one digit different mine is number 443 61 ? also the choke plunger wont stay pulled out it returns on the spring what is supposed to keep it in the choke on position ? many thanks for any help.. regards .Jez
22 Jan 2023 02:58
I THINK parts 32 and 33 on the exploded diagram on the CMSNL link keep the choke out.
I would be happy that the carb that came with your bike is the correct one - the second number could be a part supersession or a market variation.
22 Jan 2023 05:36
Replied by MarkT on topic DT 175 A carb ?
Have you checked your VIN against the VIN tables to confirm the year model is 1974? Carb 44360 is for 1974.
Carb number 44361 is for the 1975 DT175b
Very common to have title or registration with an incorrect model year... some states used "year first sold" for the model year back then as just a few years earlier, many manufacturers, including Yamaha, didn't have a distinctive "model year"... same model was sold for a few years.
Also, the bike has a manufacture date on the ID sticker on the steering head. Almost all 1975 models were actually built in 1974 and this causes confusion as to model year as well.
Either way 44361 carb will work fine.
On the choke, just buy a new plunger assembly. Often not worth trying to fix. This "might" be the one you need. www.nichecycle.com/ncs/mikuni/parts-by-c...reads-by-mikuni.html
22 Jan 2023 06:07
- jez
Thanks for all your help and advise guys .
22 Jan 2023 06:54
