Re:Different Oil Types
  • JWormy
  • JWormy's Avatar Topic Author
Different Oil Types was created by JWormy
Hi All,
I'm a 2-stroke novice here but I have been working on bikes for a while and I'm just curious to know what the difference between all the different oil types is. 2-stroke oil, SAE, Fork Oil etc. Are they ever interchangeable and what sort of problems could it cause if you use one over the other?
Thanks,
Jess
19 Oct 2022 14:28 #1
Replied by SKYDANCER46 on topic Different Oil Types
Don't over think this. Best to use the proper oils in there proper applications. Although you can use SAE motor oil in older Yamaha forks instead of fork oil and sometimes works better.
In the transmissions you can use different types of lubricates as well but i always stay with Yamaha's Trans-oil plus gear oil 20w-40 for 2 stroke gear box/ transmissions. Works extremely well with these old wet clutches.
19 Oct 2022 16:19 #2
Replied by Tom P on topic Different Oil Types
Wet clutches in old two strokes don't like the newer oils with anti-friction additives in the transmission. Makes them slip. I also use YamaLube 20w/40. For your AutoLube or premix, always use dedicated 2-stroke oil. I've been using Lucas semi-synthetic, because it's available at the local AutoZone and seems to work well. My 1971 to 1973 shop manual says to use 10w/30 motor oil in the fork tubes.
The following user(s) Liked this Post: MarkT, Ht1kid, JWormy
19 Oct 2022 18:51 #3
Replied by MarkT on topic Different Oil Types
Yes, motor oil in the forks is not just something you can do on the older models...  As Tom P. said, it's what they were designed to use.
(The switch to actual fork oil by Yamaha in the forks started sometime in the mid 70's)
The following user(s) Liked this Post: Ht1kid, JWormy
19 Oct 2022 19:17 #4
  • JWormy
Replied by JWormy on topic Re:Different Oil Types
Good info, thanks guys. I used about a tablespoon of 10w30 in the spark plug hole to lubricator the cylinder walls while I was testing my replacement stator. Figure once it’s running whatever is still in there will just be a little smoky but will eventually burn off.
Sent from my iPhone using Tapatalk
19 Oct 2022 19:58 #5
Replied by MarkT on topic Re:Different Oil Types
You're absolutely fine.  When I was a kid two stroke oil was not readily available....  Yamaha recommended two stroke oil but plain old 30 weight motor oil was listed as ok in the owner's manual too.
I put a lot of miles on my Yamaha using Chevron Delo 400 30 wt.  It was what my Dad had in the garage.
19 Oct 2022 20:51 #6
