Engine/Frame bolt.
  • Bdee
  • Bdee's Avatar Topic Author
Engine/Frame bolt. was created by Bdee
I bought a replacement bolt that fastens the engine to the bottom front of the frame (CT3) cause I was working on an electrical issue and found that the bolt was heavily pitted and covered in white corrosion. I read here that the engine bolts need to be clean for a good ground.
The replacement I got from the dealer has a dark grey coating that according to a $12 multi-meter doesn't have continuity over its surface.
Is it ok to use?
18 Aug 2022 13:38 #1
Replied by RT325 on topic Engine/Frame bolt.
Blimey, that's interesting. Wouldn't worry about it though. Just do it up tight.
The following user(s) Liked this Post: Bdee
18 Aug 2022 13:47 #2
Replied by 1971DT250 on topic Engine/Frame bolt.
Check the resistance between the engine crankcase and a bare spot on the frame.
When I put a motor back in I clean and polish one frame tab that contacts the crankcase.
The following user(s) Liked this Post: JayB, Andy L, Bdee, Sneezles61
18 Aug 2022 17:06 #3
