Dt1 seal replacement… nut removal
  • type one
  • type one's Avatar Topic Author
  • Platinum Member
  • Platinum Member
Dt1 seal replacement… nut removal was created by type one
 Is this nut normal
Thread or reverse??
Cheers
T1
DT1's mainly -
1968 AUS
1969 B scabby track bike
1969 B MX project
73 CT3 project
BMW GSA 2018
26 Feb 2022 06:38 #1
Replied by MarkT on topic Dt1 seal replacement… nut removal
I'm not aware of any reverse threads used on the 69-81 Yamaha Enduro engines.
26 Feb 2022 07:51 #2
  • type one
  • Platinum Member
  • Platinum Member
Replied by type one on topic Dt1 seal replacement… nut removal
You are right ….
just needed a little heat…. Thanks
T1
DT1's mainly -
1968 AUS
1969 B MX project
73 CT3 project
BMW GSA 2018
26 Feb 2022 07:52 #3
Replied by Pedalcrazy on topic Dt1 seal replacement… nut removal
Also for removal is quite simple with an air impact tool…like what you use to remove lug nuts and things. They spin right off without all the fuss. Re-assembly is always by hand using a torque wrench.
The following user(s) Liked this Post: type one
26 Feb 2022 10:34 #4
  • type one
  • Platinum Member
  • Platinum Member
Busy day … I have an impact driver so should have considered that option … thank you …
what torque is factory spec???
cheers
T1
DT1's mainly -
1968 AUS
1969 B MX project
73 CT3 project
BMW GSA 2018
26 Feb 2022 11:39 #5
For the go-back…I’ve found torque specs by looking through various years of Yamaha service manuals. It has also been discussed here numerous times. I can tell you that I use 50 ft lbs on the primary gear, clutch hub and output shaft sprocket nut. For the flywheel that depends on what you are working on. The 68 DT1 has such few threads and regular nut whereas 70s bikes have more threads and nut is about 50% thicker to grab more threads. I’ve never had a problem with 45-50 ft lbs on those later bikes. No Way I’d try that on the 68. I won’t be getting into my 68 motor until this summer.
Good luck!
Oh yeah…my torque numbers are for great threads. If questionable threads don’t use my numbers.
The following user(s) Liked this Post: JGersh, nhsteve
26 Feb 2022 15:55 #6
