Pin Peening Tool
  • JGersh
  • JGersh's Avatar Topic Author
Pin Peening Tool was created by JGersh
I’m looking for recommendations for peening tools used on the seat hinge pin and footpeg pins.
2 - ‘68 DT1
‘70 RT1
‘70 CT1-B
2 - ‘70 HT-1’s
‘12 Triumph Scrambler
Last edit: 07 Jan 2022 16:22 by JGersh.
07 Jan 2022 16:21 #1
Replied by Pedalcrazy on topic Pin Peening Tool
I’ve installed both using a ballpeen hammer. Yamaha drilled the centers so they mushroom out easily. Put it on the top of a vise for a solid backing. You might be surprised how little effort it will take. Don’t get um to tight. I’ll be doing the ones on my 68 this spring so if you discover a better method please share.
The following user(s) Liked this Post: Rick C., MarkT, JGersh
07 Jan 2022 17:36 #2
Replied by MarkT on topic Pin Peening Tool
A lifetime ago the truck shop I worked in used to buy brake shoe blocks we'd rivet with similar rivets...  The rivets were called "semi tubular".
We had a foot operated tool with a flat anvil to support the flat end and a specially shaped pin that would roll the end of the rivet over perfectly.
I've also seen it done with a special bit on an air chisel.. again with flat end of rivet securely supported.
Here's a link that shows what the end of the tool looks like.  Not sure where to buy one cheap enough but might be able to make one?
rivetsinstock.com/rivet-tools/solid-semi...lar-rivet-tools.html
The following user(s) Liked this Post: JGersh, Ht1kid
07 Jan 2022 18:14 #3
07 Jan 2022 18:21 #4
  • JGersh
Replied by JGersh on topic Pin Peening Tool
Searching Semi Tubular Rivet Tools took me to these guys who are nearby.  Going to call Monday.  Thanks for the guidance Mark and Pedal.
www.hansonrivet.com/tools-machines/solid...and-rivet-clinchers/
2 - ‘68 DT1
‘70 RT1
‘70 CT1-B
2 - ‘70 HT-1’s
The following user(s) Liked this Post: MarkT, Pedalcrazy
07 Jan 2022 18:45 #5
NICE!  And their prices aren't too terrible.  Let us know how you make out.
07 Jan 2022 18:51 #6
Replied by Gr8uncleal on topic Pin Peening Tool
I just thought "sod it" and used clevis pins and R clips!
08 Jan 2022 00:23 #7
Replied by Pete-RT1 on topic Pin Peening Tool
I did both my footpegs and seat clasp using a centre punch and a ball peen hammer.
Centre punch to swell the rivet out and the ball peen hammer to swage over the end, repeat a few times and it's done.
As Pedalcrazy said, support the other end of the rivet on a vice or similar and away you go, it's far easier than you might imagine.
Good luck.
Yamaha CT3 (in bits)
The following user(s) Liked this Post: JGersh, Pedalcrazy
08 Jan 2022 01:49 #8
