Float rod plastic caps
  • my68dt1
  • my68dt1's Avatar Topic Author
Float rod plastic caps was created by my68dt1
On my 68 Yamaha I am trying to remove the floats. There is a small plastic cap on the float rod. I tried pulling the cap off. I thought I had better find out if there is a trick to removing these things before  I screw them up. I will probably never find another. Any. thoughts? Stan
04 Jan 2022 19:42 #1
Replied by adguy2112 on topic Float rod plastic caps
Just use your thumbnail. Needle nose pliers work too. Easy to lose. I lost mine and now put the bowl on from the bottom. They just make it easier to install the bowl.
04 Jan 2022 20:31 #2
Replied by RT325 on topic Float rod plastic caps
Be careful not to bend the rods as easy to do. I just use some small side cutters out of my wife's sewing box [not missed them yet lol] & just lever them over & off. Do you really need to remove the floats. Favourite trick is putting the floats on the pins upsidedown. Guy at work did on a TD2 250 twin roadracer when new [had to have a play] then turned up at the race & it wouldn't run haha.
Last edit: 04 Jan 2022 20:52 by RT325.
04 Jan 2022 20:51 #3
Replied by Pedalcrazy on topic Float rod plastic caps
Anything original on these bikes that was flexible at all is now hardened. I use a heat gun for many tasks that I don't want to ruin an originally soft part. Just be aware of what you are doing with hot items around fuel. With the carb apart I wouldn't hesitate to use a heat gun. I've removed/reinstalled a number of them to clean/polish those rods.
05 Jan 2022 14:53 #4
Replied by Swoop56 on topic Float rod plastic caps
I have softened the plastic caps in close to boiling hot water .
They were much easier to remove or install once softened .
05 Jan 2022 17:09 #5
