RT1 Compression
- ckjacks
RT1 Compression was created by ckjacks
My 1971 RT1 360 is back together but not running right. It does not want to rev out. When it gets to about 5000 RPM's it starts stuttering and will not go any higher. I have not checked the compression and was wondering what it should be on a healthy engine. Any ideas on the stuttering would be greatly appreciated. It feels or seems like the timing is off but it is set correctly (I think!). Thank you all!!
16 Nov 2021 07:40
Replied by Gr8uncleal on topic RT1 Compression
Correct carb, jets and air filter? Also, maybe the air filter has been over oiled? Perhaps try, briefly, without the air filter in place, just to see what difference this makes.
Bunged up exhaust might also lead to your symptoms.
- ckjacks
Replied by ckjacks on topic RT1 Compression
Thanks. Carb has been cleaned and jets are stock. I thought about the air filter, too. It doesn't look too oily but I am going to try it without it. I cleaned the end of the exhaust where the removable tip is. Not sure about further up.
16 Nov 2021 08:31
And it's the correct carb for the bike? I only ask, because I found out rather late in the day that my own RT2 had a carb from a RT1 carb fitted. Also, my CT1 came to me with a CT2 carb fitted!
16 Nov 2021 08:37
- ckjacks
Checked it last night and looks to be the right carb. Does anyone have a compression spec for this bike??
17 Nov 2021 06:22
Replied by MarkT on topic RT1 Compression
How is the o-ring seal in the bottom of the float bowl?
The following user(s) Liked this Post: Hardworker
17 Nov 2021 06:33
"Checked it last night and looks to be the right carb. Does anyone have a compression spec for this bike??"
Going from answers to previous posts on this subject, I don't think that Yamaha published any compression specs. Happy to be corrected, though.
Replied by RT325 on topic RT1 Compression
By stuttering, if you mean rich 4 stroking symptoms there's really only two reasons--well 3 maybe if somethings blocking the airbox intake--. So two are--Carb jet setter Oring sealing into the bowl & hence the main jet. Other important one--my first pick-- is the exhaust restriction in the spark arrestor in the end section & probably a built in item not removable.
- ckjacks
Thank you. I thought the o ring was OK when I cleaned the carb, but maybe it did not get re-installed properly. I'll check it this weekend.
17 Nov 2021 14:36
- ckjacks
Thanks, Mark. I know that O ring is critical. I will recheck it this weekend!
17 Nov 2021 14:38
