Lost the @$%@&@* circlip
  • principal282
  • principal282's Avatar Topic Author
Lost the @$%@&@* circlip was created by principal282
Fell down the crankcase hole
catastrophic or no?
Best way to find?
03 Oct 2021 16:09 #1
Replied by MarkT on topic Lost the @$%@&@* circlip
You need to get it out of there or it will be catastrophic.
Sometimes a magnet works.  Sometimes a little thick oil or even grease and turning over crank slow with rod will drag it to the top.
Or if engine is out you can try turning it upside down.
Also sometimes you think it fell in but didn't.
P.S.  Assembly 101 is to cover bottom end with rags when removing and installing clips.
The following user(s) Liked this Post: HouseofEnduro, Ht1kid, Pedalcrazy
03 Oct 2021 16:19 #2
Replied by RT325 on topic Lost the @$%@&@* circlip
Blimey, you're having all the luck. Catastrophic if left in there. Good magnet stick should catch it. Not a $2 shop stick where the end loff & you have two things stuck down there. Otherwise turn motor --or bike-- upside down totally, but have something to catch it incase it goes past & lost without seeing it go, then thinking its still in there hiding.
03 Oct 2021 16:21 #3
  • principal282
Replied by principal282 on topic Lost the @$%@&@* circlip
I gave up for the night but I can see it in there. Couldn't hook it with a long wire.  The 5 dollar gas station one did not work too fat.  I will acquire one and press on. Learned a lesson today
03 Oct 2021 17:42 #4
  • principal282
And I had the hole covered to start. Trouble getting the rings to compress so took to the bench. Doggone it!!  One careless moment...
03 Oct 2021 18:13 #5
  • darinm
  • darinm's Avatar
  • Platinum Member
  • Platinum Member
Replied by darinm on topic Lost the @$%@&@* circlip
Sounds crazy but in my experience honey works better than thick grease.
1972 Yamaha CT2 175
1972 Suzuki TS185 Sierra
1997 BMW R1100R
2009 BMW X-Country 650
2013 Yamaha XT250
2020 Zero DSR
03 Oct 2021 18:25 #6
Scratch a flat blade screwdriver on a flywheel magnet a few times & you'll hook it out.
03 Oct 2021 20:03 #7
  • principal282
Yes!! The offending circlip is OUT. I charged a long bolt with my dial gauge magnet. Out it came.  Whew!! Okay rookie lesson learned.
The following user(s) Liked this Post: Pedalcrazy, msavitt
03 Oct 2021 20:11 #8
Yay, good one.
03 Oct 2021 20:13 #9
Congratulations!
Ummm... and yeah...  not just a "rookie mistake"...  some of us know better and it still happens.
03 Oct 2021 20:20 #10
