Air and idle 73 dt3
  • principal282
  • principal282's Avatar Topic Author
Replied by principal282 on topic Air and idle 73 dt3
Cleaned again. Every piece apart.
soaked in simple green then boiling water..
Fouled Up when i dropped the pilot into the overflow. I drilled it out carefully.
This is what the simple green and boiling water took out, along with a good power air nozzle
If you look you can see lots of crap.
We shall know in ten minutes
05 Sep 2021 16:25 #11
Replied by MarkT on topic Air and idle 73 dt3
So many times it's just the carb needs cleaning...  maybe a few times.
P.S.  Choke jet RT325 mentioned is at bottom of well in float bowl.
05 Sep 2021 16:29 #12
  • principal282
I was careful and ran a thin wire there...and blew it out good.
starts good, idles okay, sputters still
Could I be getting too much oil mix? Too much putt putt and not enough going for a good rip?
05 Sep 2021 17:51 #13
Replied by Swoop56 on topic Air and idle 73 dt3
You have made no mention of removing the needle jet and cleaning that out .
They can collect crap around the chamber it slots into .
05 Sep 2021 17:57 #14
  • principal282
Main jet out and clean.
I took apart the main nozzle and o ring jet setter and cleaned that.  Am I missing something
05 Sep 2021 19:13 #15
I think the question was if you removed the main brass main nozzle aka needle jet from the carb body?
I'm also confused on the issue.  The videos show it idling, right?
P.S.  Is plug gapped 0.020" to 0.024"?  Running non-resistor plug or a non-resistor cap?
05 Sep 2021 19:42 #16
  • principal282
Gap is set to .02
it does idle
yes needle jet (along with pilot, main, etc) all cleaned up
05 Sep 2021 19:54 #17
Again, I'm not sure what you're looking for?  Are you expecting it to idle when cold like a computer controlled fuel injected engine?
05 Sep 2021 20:13 #18
  • principal282
It idles okay, but sputters and spits when going down the road. Lacks power.
05 Sep 2021 20:35 #19
  • RT325
  • RT325's Avatar
  • Platinum Member
  • Platinum Member
Replied by RT325 on topic Air and idle 73 dt3
I'm a page behind, but the spark arrestor shown is part of the end piece looking at the parts list. If i hadn't looked i would have said its spot welds have let go deep down in the tail of the exhaust. But now looks like its welds have let go on the pipe shown, or been cut off. Can leave it out, but with rules on spark arrestors for you guys it might pay to weld it back on as at least it'll come out with the tail pipe to be cleaned as stray carbon lumps can get caught in them & instant horsepower loss. Not sure if it would have to be set at a certain position to line up with something but doubt it. It probably just fits closely down in there. Have a good look with a light.
The following user(s) Liked this Post: principal282
06 Sep 2021 02:26 #20
