Yamaha DT125 Enduro 12 Volt system electric start firing issues
- Makotosun
- Administrator
Replied by Makotosun on topic Yamaha DT125 Enduro 12 Volt system electric start firing issues
SORRY THE VIEW DOC DOESN'T SEEM TO BE WORKING IN THE CURRENT CONFIG. I have disabled the view approach, but the download seems to be working fine?
Thanks.
Mako
Thanks.
Mako
The following user(s) Liked this Post: Patroll330
14 Mar 2021 18:07
#11
- Patroll330
Replied by Patroll330 on topic Yamaha DT125 Enduro 12 Volt system electric start firing issues
i tried cleaning those points with electronic spray cleaner ,used a dollar bill to wipe them off but it sparks irediclly .I got it to spark once at the spark plug but t6hats about it it seeems shorted at the points . Points must be very hard to get right and the timing . The points wouldn't even open up so I did open them to about .013 thousands . And now my starter is working and turning the engine over. How to change points and condenser and check the timing?
14 Mar 2021 20:58
#12
- Mothersbaugh
Replied by Mothersbaugh on topic Yamaha DT125 Enduro 12 Volt system electric start firing issues
If you are getting something out of the points in the way of a spark rather than nothing, you are on the right track. The best way to clean the points is with a business card or some worn out 600 wet or dry. drag the wet or dry (my choice) through once, and then drag it through again with the gritty side the other way. Maybe twice each direction at most should freshen them up. Then dry to start it.
14 Mar 2021 22:57
#13
Replied by RT325 on topic Yamaha DT125 Enduro 12 Volt system electric start firing issues
Pull the plug cap off the lead & set the lead down between two head fins & spin it on the starter. If spark jumps to the fins then it’s looking good. But if the spark Jumps & the points spark wildly then maybe you have a condenser problem. Run out of ideas at the moment.
14 Mar 2021 23:28
#14
- pabdt
Replied by pabdt on topic Yamaha DT125 Enduro 12 Volt system electric start firing issues
That bike has a timing pointer for the yoke. When lined up you can expand the cam advance and set the points provided the pointer hasn't been messed with. That will likely get you up and running.
1974 Yamaha DT360A
1973 Yamaha DT3 250
1974 Yamaha DT125A
1969 Yamaha DT1S 250
1969 Yamaha CT1 175
1974 Yamaha DT360A
1973 Yamaha DT3 250
1974 Yamaha DT125A
1969 Yamaha CT1 175
The following user(s) Liked this Post: RT325, Patroll330
