are the spark plug leads replaceable without changing coil 1970s CT/DT etc
- s900t8v
are the spark plug leads replaceable without changing coil 1970s CT/DT etc was created by s900t8v
hey guys
I havent tried but are the spark plug leads on the CT175 and early DT175 replaceable? can I unscrew them oror are they bonded to the coil?
thanks
thanks
1976 Yamaha AG175 cafe
1969 Yamaha L5T
1979 Yamaha Rx125
1954 Puch 175 Sv
1951 Puch 250TF
1969 Yamaha L5T
1979 Yamaha Rx125
1954 Puch 175 Sv
1951 Puch 250TF
05 Sep 2020 05:25
Replied by MarkT on topic are the spark plug leads replaceable without changing coil 1970s CT/DT etc
Have to see the coil. Some do unscrew, some don't. Usually pretty easy to tell if bonded.
05 Sep 2020 07:06
- s900t8v
Replied by s900t8v on topic are the spark plug leads replaceable without changing coil 1970s CT/DT etc
thanks mark its just under the tank so I was being a bit lazy ha!
cheers
cheers
1969 Yamaha L5T
1979 Yamaha Rx125
1954 Puch 175 Sv
1951 Puch 250TF
1969 Yamaha L5T
1979 Yamaha Rx125
1954 Puch 175 Sv
1951 Puch 250TF
06 Sep 2020 15:04
I'm not even sure exactly what bikes you're talking about... early CT in the USA had a sort of threaded cap around the wire like the RD350... cap comes off and then wire unscrews.
I also understand lazy...
What I'd do is search ebay for the coil... select "used" in the filters... and then look at the pictures of the used parts for sale... a few different types of coils might come up because someone could have swapped parts or sellers get confused... but usually not too hard to decide which type is original unless there are only one or two listings... worth a try.
06 Sep 2020 15:45
