CT3 source and lighting coil clean up.
- shyted
CT3 source and lighting coil clean up. was created by shyted
The ignition component source & lighting coil assembly is in a bit of a state as is the mount plate from my CT3.
I have welded the plate ,as it was cracked at the bottom and cleaned it up.
New screws and washers,points and condenser.
However how can i clean the coil components them selves ?
I have bought some insulating varnish to finish up afterwards but not sure how sensitive they would be to say soaking in acetone and polishing with a rag ?
There is rust on the coil mount but the copper on the coil is tarnished to hell.
Any suggestions ?
Regards Ted
Any suggestions ?
Regards Ted
21 Aug 2020 13:08
- yamahahaha
Replied by yamahahaha on topic CT3 source and lighting coil clean up.
21 Aug 2020 14:45
- shyted
Replied by shyted on topic CT3 source and lighting coil clean up.
Great ,thanks Yamahahaha.
Just want to make sure the Evaporust for sale here is the same as in the US.
Does yours come in a grey container with a purpleish coloured label like this ?
21 Aug 2020 23:21
Replied by Gr8uncleal on topic CT3 source and lighting coil clean up.
That's the stuff that I have used Dave, although not on the specific components that you're looking at.
Very useful that it can be re-used. Talking of which, can phosphoric acid be re-used (I've got about 6 petrol tanks that need cleaning out!
21 Aug 2020 23:55
- shyted
Yes is the answer Al.
I have also discovered something with Phosphoric.
Don't rinse it with water ! Wipe or air / heat gun dry it.
Nothing goes rusty afterwards.
21 Aug 2020 23:59
Thanks!
22 Aug 2020 02:19
- yamahahaha
Yes that is it... Like I said I did my stator as a last resort with the Evaporust... I did not worry so much soaking the flywheel.. It was also really crusty... Hope it works for you...
One thing I did learn first hand is that if you soak something long enough that has been painted it WILL remove the paint... I think Evaporust CLAIMS it will not harm paint but I found that it will if left soaking long enough... I forgot I had something soaking and after 3 days it started on the paint...But we are talking 72 hours or so... More than a senior moment DUH
