Ct1c oil eater
  • Blukas
  • Blukas's Avatar Topic Author
Ct1c oil eater was created by Blukas
I’ve got a bad oil eating situation, motor eats up the transmission fluid and the exhaust is soaked with it, also it’s down on power from it. I changed both cranks seals so what else could it be? Found these things In the bottom of the cover. What are they?
18 Aug 2020 08:46 #1
Replied by msavitt on topic Ct1c oil eater
holy smokes
does the shifter ratchet thru the gears properly?
those cylindrical items look like the pins on the shit drum
18 Aug 2020 10:16 #2
Replied by Gr8uncleal on topic Ct1c oil eater
My oh my, what a great typo! :EEEK :EEEK :EEEK :ROFLOL :ROFLOL :ROFLOL
Edit - I assume it IS a typo.................!!
Last edit: 18 Aug 2020 11:47 by Gr8uncleal.
18 Aug 2020 11:47 #3
Replied by darinm on topic Ct1c oil eater
If those are out of the shift drum that is probably an accurate assessment of its current condition!
1972 Yamaha CT2 175
1972 Suzuki TS185 Sierra
1997 BMW R1100R
2013 Yamaha XT250
18 Aug 2020 11:50 #4
Can't argue with that - perfect logic!
18 Aug 2020 11:51 #5
  • Blukas
Replied by Blukas on topic Ct1c oil eater
Yeah lol, shifter drum is together and shifting, everything seems to be working fine and it worked fine before I took it apart to change the gasket and the oil eating problem. Does anyone know if there are needle bearings in this thing? It doesn’t even seem like those needles even belong there.
18 Aug 2020 11:58 #6
Replied by Pedalcrazy on topic Ct1c oil eater
Well I believe the upper and lower rod bearings are needles and probably one or two needle bearings in the trans. At least on the 360 and 400 there are. I’m pretty sure ethey belong in there unless you don’t know the history of the bike and some little gremlin dumped them in there.
The small bits look like what’s left of the bearing retainer (cage that holds the needles).
Last edit: 18 Aug 2020 15:02 by Pedalcrazy.
18 Aug 2020 14:59 #7
I could pretend that i am clever, but that was a typo!
18 Aug 2020 15:11 #8
Replied by RT325 on topic Ct1c oil eater
Needle bearings from the bearing in the case where the lay shaft has the idler gear hanging on it. Ok i'll go read the story more thoroughly
18 Aug 2020 15:50 #9
Last edit: 18 Aug 2020 15:59 by RT325.
18 Aug 2020 15:58 #10
