The next project found abandoned on a ride
Replied by mdscott on topic The next project found abandoned on a ride
A few of my bikes I welded were it was worn, then ground down to get the lever in a flat position. My KDX200 was the latest.
Thanks Mark
Roseville, Ca.
'03 ST1300
'75 Norton
'73 CB500K
'81 Honda CT110
'87 PW50
'64 McClane Edger
'65 Honda S90
31 Oct 2020 13:31 #51
  • Delcowizzid
  • Delcowizzid's Avatar Topic Author
Replied by Delcowizzid on topic The next project found abandoned on a ride
Upholsterer couldn't get the Taiwanese seat cover to work so he pulled this out of his arse non slip as hell almost better looking than the stock cover should be perfect for the hard enduro riding I do. Shock rebuild got expensive the shaft was buggered and needed rechromed but should be all fixed in a week just got the Kx250 spring all painted ready to go on
01 Nov 2020 22:13 #52
  • Delcowizzid
Got my rebuilt shock in cost a bit but should ride good looks cool on the ground
The following user(s) Liked this Post: Rick C., MarkT, 2fishkev
16 Nov 2020 02:01 #53
Looks like you race the Mini Cooper.
Thanks Mark
Roseville, Ca.
'03 ST1300
'75 Norton
'73 CB500K
'81 Honda CT110
'87 PW50
'64 McClane Edger
'65 Honda S90
16 Nov 2020 08:05 #54
  • Delcowizzid
That's my mates drag car 355 chev powerglide 4 linked rear 28x13.5-15 on the rear
20 Nov 2020 04:36 #55
  • Delcowizzid
First time it's been running in a while quick bolt check and be ready to tech and race
20 Nov 2020 04:40 #56
  • Delcowizzid
Pretty much the last peice of the puzzle just came back from getting bored and recoated with nicasil ready to assemble the engine
04 Dec 2020 02:38 #57
  • Delcowizzid
Crank is in cases sealed and bolted together hopefully finish the whole bottomend tomorrow and test fit the piston and barrel with no rings and check all the nessisary clearences before fitting it for good. Crank sat in the freezer for 2 days chilling and had to heat the bearing on one side and drop it in
10 Dec 2020 03:39 #58
  • Delcowizzid
Nearly the end now engine is assembled and back in the frame I added a second charge coil wire and floated the earth to use a proper rectifier regulator for solid 12v lighting etc once the engine was in. now working on a new loom for the entire bike
The following user(s) Liked this Post: darinm, Pete-RT1
12 Dec 2020 04:57 #59
  • Delcowizzid
Pulled the carb right down unbolted the jetblock out of it put it all in the ultrasonic for 20 minutes came out sparkling clean all reassembled with all new parts inside on the bike ready to go
The following user(s) Liked this Post: Makotosun, MarkT
13 Dec 2020 21:57 #60
