The next project found abandoned on a ride
  • Delcowizzid
  • Delcowizzid's Avatar Topic Author
Replied by Delcowizzid on topic The next project found abandoned on a ride
New front wheel bearings are In and wheel is on piston and main bearings and seals ordered should be able to send the barrel off to be replated next week and get the conrod and new crank pin pressed together
21 Sep 2020 01:10 #41
  • Delcowizzid
Time to build the engine 1mm over wossner coated piston Royal conrod kit new main bearings and seals gaskets air filter etc
Will prep the barrel ready to be sent away tomorrow for over bore and nikasil coating then she can all go together. Just waiting on carburetor parts now
27 Sep 2020 16:07 #42
  • Delcowizzid
Crank is off getting the new rod and crank pin fitted rear shock should be all rebuilt this week swingarm all prepped and painted in Dupli-Color stainless Steel rear spring getting prepped for a fresh coat of green light at the end of the tunnel may get the motor and swingarm in this weekend if everything arrives. Same stainless paint matches the engine covers that are plastic like the flywheel cover and kipps actuator covers
The following user(s) Liked this Post: Von
05 Oct 2020 02:20 #43
  • Delcowizzid
And the brand new kawasaki oem Kick-start to seal the deal haha
The following user(s) Liked this Post: Rick C., MarkT
05 Oct 2020 02:22 #44
  • Delcowizzid
Got some clear on the swingarm
11 Oct 2020 23:04 #45
  • Delcowizzid
My extremely cheap aftermarket headlight arrived the colours good but I don't know if I like the look of it haha
19 Oct 2020 01:23 #46
Replied by Fogrider on topic The next project found abandoned on a ride
Beware of unavailable power valve parts. Ran into that with a KDX 200. Had to have them made at a machine shop, ouch!
20 Oct 2020 13:52 #47
  • Delcowizzid
I repaired one valve can buy a full aftermarket set in steel here for 200 dollers
20 Oct 2020 22:56 #48
Replied by s900t8v on topic The next project found abandoned on a ride
I always remmber the little tang bending so your foot would slip off the kickstart! I always ended up putting a screw in there so it sat square when rotated out to start the bike.
1976 Yamaha AG175 cafe
1969 Yamaha L5T
1979 Yamaha Rx125
1954 Puch 175 Sv
1951 Puch 250TF
21 Oct 2020 00:01 #49
  • Delcowizzid
She's nearly on the ground hopefully get the rebuilt shock back this week and get the crank and main bearings in it and the bottomend in the frame to stay
The following user(s) Liked this Post: MarkT, Steve F, Pete-RT1
31 Oct 2020 00:13 #50
